필요한 것
The screen assembly I am using in this tutorial arrived encased in foam, bubble wrap and styrophome. Quite a pleasure to unpack.
Start with removing the 4 corner screws and the two center screws from around the bottom panel. **NOTE the screws next to the hinge are a different length (longer) than the two at the other two corners, and the two center screws are the shortest. so keep that in mind when putting your MacBook back together.
Now comes the hinge screws. Actually, for the next few steps it probably does not matter what order you remove the screws. But I did the hinges next. These require a T8 diver.
I forgot to get a picture of the hinge caps that will need to be removed first. These required a P3 driver, and the screws are very tiny. Once these screws were removed you can pry off the hinge caps and access the hinges.
다른 79명이 해당 안내서를 완성하였습니다.
댓글 23개
This guide sucks really bad.. missed steps. so unclear about everything. crappy pictures, I suggest you re do this whole thing.
Good guide for someone with experience. I would add a few extra steps with more details, including some additional warnings since having a beginner follow this guide could result in failure in repairing the device. PLEASE HAVE SOMEONE WITH EXPERIENCE PERFORM THIS REPAIR!
This worked perfectly and saved me a lot of money. Many thanks.
