이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계에 사용된 도구:Magnetic Project Mat$19.95
하단 케이스를 상단 케이스에 고정하는 다음 나사 열 개를 풀어주세요:
2.3mm P5 Pentalobe/펜타로브/별나사 두 개
3.0mm P5 Pentalobe/펜타로브/별나사 여덟 개
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Peel away any stickers from the backside of the rear case covering the feet you have chosen to replace.
Remove any broken or damaged feet.
If the old foot is difficult to remove, use a hair dryer or a heat gun to apply some heat to the area and loosen the adhesive.
Scrub the foot cavity with adhesive remover to remove any remaining adhesive.
Wipe the foot cavity with an isopropyl alcohol prep pad to remove any cleaner residue and prep the area for the adhesive on the new foot.
Align the new foot inside the cavity.
Lay the foot down while keeping it properly aligned.
Check for proper alignment from the inside of the case. The alignment nub should be slightly visible through the alignment hole.
Press the new foot into place firmly with your finger, then apply pressure by pinching the foot from either side of the case with your finger and your thumb.
Maintain pressure for 30 seconds to set the pressure-sensitive adhesive.
Repeat the last seven steps for any remaining broken or worn feet.
다른 8명이 해당 안내서를 완성하였습니다.
댓글 한 개
Great kit for replacing the feet on a MacBook. Had a foot fall off my 6 year old MacBook Pro and this kit fit exactly!
