주요 콘텐츠로 건너뛰기
MacBook Pro 13" Retina Display Early 2013 Lower Case Replacement
필요한 것
    • Two 2.3 mm P5 Pentalobe screws
    • Eight 3.0 mm P5 Pentalobe screws
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your device.
  1. MacBook Pro 13" Retina Display Early 2013 Lower Case Replacement: 2 단계, 이미지 1/1
    • Wedge your fingers between the upper case and the lower case.
    • Gently pull the lower case away from the upper case.
  2. MacBook Pro 13" Retina Display Early 2013 Lower Case Replacement: 3 단계, 이미지 1/3 MacBook Pro 13" Retina Display Early 2013 Lower Case Replacement: 3 단계, 이미지 2/3 MacBook Pro 13" Retina Display Early 2013 Lower Case Replacement: 3 단계, 이미지 3/3
    • During reassembly, gently push down the center of the lower case to reattach the two plastic clips.
    • The lower case is connected to the upper case at the center, with two plastic clips.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Sam Goldheart
회원 가입일: 10/18/12
458,786 평판
안내서 538개 작성하였습니다
iFixit iFixit 회원
Community
140 회원들
안내서 17,590개 작성하였습니다
댓글 한 개
tell me the size of screw driver
nigamyadav56 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 9
30일 전: 38
전체 시간: 10,423
