주요 콘텐츠로 건너뛰기
MacBook Pro 13" Retina Display Early 2015 Display Assembly Replacement
필요한 것
  1. MacBook Pro 13" Retina Display Early 2015 Display Assembly Replacement, Lower Case: 1 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    Magnetic Project Mat
    $19.95
    • Two 2.3 mm P5 Pentalobe screws
    • Eight 3.0 mm P5 Pentalobe screws
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your device.
  2. MacBook Pro 13" Retina Display Early 2015 Display Assembly Replacement: 2 단계, 이미지 1개 중 1개
    • Wedge your fingers between the upper case and the lower case.
    • Gently pull the lower case away from the upper case to remove it.
  3. MacBook Pro 13" Retina Display Early 2015 Display Assembly Replacement: 3 단계, 이미지 2개 중 1개 MacBook Pro 13" Retina Display Early 2015 Display Assembly Replacement: 3 단계, 이미지 2개 중 2개
    • The lower case is connected to the upper case with two plastic clips near its center.
    • During reassembly, gently push down the center of the lower case to reattach the two plastic clips.
  4. MacBook Pro 13" Retina Display Early 2015 Display Assembly Replacement, Battery Connector: 4 단계, 이미지 1개 중 1개
    • If necessary, remove the plastic cover adhered to the battery contact board.
  5. MacBook Pro 13" Retina Display Early 2015 Display Assembly Replacement: 5 단계, 이미지 2개 중 1개 MacBook Pro 13" Retina Display Early 2015 Display Assembly Replacement: 5 단계, 이미지 2개 중 2개
    • Use the flat end of a spudger to lift the battery connector straight up out of its socket on the logic board.
    • Be sure you lift up only on the connector itself, not the socket, or you risk permanent damage to the logic board.
  6. MacBook Pro 13" Retina Display Early 2015 Display Assembly Replacement: 6 단계, 이미지 1개 중 1개
    • Bend the battery connector up out of the way to prevent accidental contact with its socket during your repair.
  7. MacBook Pro 13" Retina Display Early 2015 Display Assembly Replacement, Display Assembly: 7 단계, 이미지 3개 중 1개 MacBook Pro 13" Retina Display Early 2015 Display Assembly Replacement, Display Assembly: 7 단계, 이미지 3개 중 2개 MacBook Pro 13" Retina Display Early 2015 Display Assembly Replacement, Display Assembly: 7 단계, 이미지 3개 중 3개
    • Carefully peel the rubber fan bumper from the edge of the heat sink to expose the iSight camera cable adhered to the fan.
    • The fan bumper wraps around the heat sink and fits into the fan duct slots. During reassembly, be sure to fit the tabs into the notches in the fan duct.
  8. MacBook Pro 13" Retina Display Early 2015 Display Assembly Replacement: 8 단계, 이미지 3개 중 1개 MacBook Pro 13" Retina Display Early 2015 Display Assembly Replacement: 8 단계, 이미지 3개 중 2개 MacBook Pro 13" Retina Display Early 2015 Display Assembly Replacement: 8 단계, 이미지 3개 중 3개
    • Insert the tip of a spudger under each of the antenna cables near their connectors and pry up to disconnect them from the AirPort board.
    • The three cables are coded with black sleeves of different lengths. During reassembly:
    • Connect the long-sleeved cable to the center socket.
    • The short-sleeved cable connects next to the screw.
    • The remaining cable has no sleeve, and connects in the last empty socket, next to the fan.
  9. MacBook Pro 13" Retina Display Early 2015 Display Assembly Replacement: 9 단계, 이미지 2개 중 1개 MacBook Pro 13" Retina Display Early 2015 Display Assembly Replacement: 9 단계, 이미지 2개 중 2개
    • Use the tip of a spudger to push on either side of the the iSight camera cable connector to walk it out of its socket on the logic board.
  10. MacBook Pro 13" Retina Display Early 2015 Display Assembly Replacement: 10 단계, 이미지 2개 중 1개 MacBook Pro 13" Retina Display Early 2015 Display Assembly Replacement: 10 단계, 이미지 2개 중 2개
    • Peel the iSight camera cable up off the fan housing.
  11. MacBook Pro 13" Retina Display Early 2015 Display Assembly Replacement: 11 단계, 이미지 3개 중 1개 MacBook Pro 13" Retina Display Early 2015 Display Assembly Replacement: 11 단계, 이미지 3개 중 2개 MacBook Pro 13" Retina Display Early 2015 Display Assembly Replacement: 11 단계, 이미지 3개 중 3개
    • Grab the black plastic tab to flip the display cable connector open and pull it straight out of its socket on the logic board.
    • During reinstallation, be sure to fully reseat the display connector tab.
  12. MacBook Pro 13" Retina Display Early 2015 Display Assembly Replacement: 12 단계, 이미지 3개 중 1개 MacBook Pro 13" Retina Display Early 2015 Display Assembly Replacement: 12 단계, 이미지 3개 중 2개 MacBook Pro 13" Retina Display Early 2015 Display Assembly Replacement: 12 단계, 이미지 3개 중 3개
    • Remove the rubber hinge covers from the right and left display hinges.
  13. MacBook Pro 13" Retina Display Early 2015 Display Assembly Replacement: 13 단계, 이미지 2개 중 1개 MacBook Pro 13" Retina Display Early 2015 Display Assembly Replacement: 13 단계, 이미지 2개 중 2개
    • Remove the two 4.2 mm T5 Torx screws securing the aluminum hinge brackets (one on each side of the Macbook).
  14. MacBook Pro 13" Retina Display Early 2015 Display Assembly Replacement: 14 단계, 이미지 3개 중 1개 MacBook Pro 13" Retina Display Early 2015 Display Assembly Replacement: 14 단계, 이미지 3개 중 2개 MacBook Pro 13" Retina Display Early 2015 Display Assembly Replacement: 14 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Use a pair of tweezers to lift aluminum hinge brackets off the right and left display hinges.
    • During reassembly, the vertical portion of the bracket should be in line with the aluminum rail in the center of the Macbook.
  15. MacBook Pro 13" Retina Display Early 2015 Display Assembly Replacement: 15 단계, 이미지 2개 중 1개 MacBook Pro 13" Retina Display Early 2015 Display Assembly Replacement: 15 단계, 이미지 2개 중 2개
    • Remove the four outer 5.3 mm T8 Torx screws (two on each side) securing the display to the upper case.
    • Some models may use T9 Torx screws rather than T8.
    • If the rubber hinge cover adhesive is still on the screw heads, use tweezers to peel and remove it.
  16. MacBook Pro 13" Retina Display Early 2015 Display Assembly Replacement: 16 단계, 이미지 2개 중 1개 MacBook Pro 13" Retina Display Early 2015 Display Assembly Replacement: 16 단계, 이미지 2개 중 2개
    • Open the MacBook Pro a little wider than 90 degrees, and place it on end on the table, as shown.
    • While holding the display with your left hand, remove the remaining T8 Torx screw from the upper display bracket.
    • Be sure the display and upper case are balanced and will not fall, potentially damaging each component.
    • Remove the last remaining T8 Torx screw securing the display to the upper case.
  17. MacBook Pro 13" Retina Display Early 2015 Display Assembly Replacement: 17 단계, 이미지 3개 중 1개 MacBook Pro 13" Retina Display Early 2015 Display Assembly Replacement: 17 단계, 이미지 3개 중 2개 MacBook Pro 13" Retina Display Early 2015 Display Assembly Replacement: 17 단계, 이미지 3개 중 3개
    • Grab the upper case with your right hand and rotate it slightly clockwise, toward the top of the display, so the display brackets clear the edge of the upper case.
    • Rotate the display slightly away from the upper case.
    • Pull the display away from the upper case, minding any brackets or cables that may get caught.
결론
다른 233명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Andrew Optimus Goldheart
회원 가입일: 10/17/09
512,335 평판
안내서 407개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 23,663개를 작성함
60가이드 댓글
Just did this for my wife. Awesome! Thank you!
Josh Way - 답글
Just complete this over lunch and it was cake - no pun. Follow the instructions and you'll be back to new in about 30 minutes. The toughest part is getting all those little screws out, so be patient and just know it's worth the squeeze. Take care, AZ
Advisor King - 답글
Is display assembly for Late 2013/Mid 2014 compatible with this model?
Payton James - 답글
Hi, I have same question, and I think its not fully compatible, I tried to put 2014 display on 2015 and its have issue with backlight at startup, for example if you press "ALT" at startup to chose startup disk, screen remains all the time dark only with flash light you can see its working and if you chose disk and only after some 5 seconds backlight will turn on, if I put old original broken display but with working backlight it will turn on backlight straight with the "chime" and yes with new 2014 display its not lighting up straight after chime only after some 5 seconds or so, but after that works fine.
artc -
Hi, last night i was watching a movie in my MBP E2015, and out of nothing, gave me "the gift" of a black screen... i tried everything i found in forums, reset SMC PRAM/NRAM, safe mode, force reboot, well, you name it, i tried it with no luck... i opened the MB and re-connected the display cable to what see if something happens, and nothing... i can only see the contents of the screen when using HDMI on a tv (i also can see stuff in the screen when pointing a flashlight in the dark screen, that makes me think its fixable) should i start thinking of replacing the whole display? any suggestion would be appreciated, thanks!
DanielD
Daniel Dugarte - 답글
댓글 쓰기
조회 통계:
지난 24시간: 43
지난 7일: 310
지난 30일: 1,864
전체 시간: 248,201
