주요 콘텐츠로 건너뛰기
MacBook Pro 13" Retina Display Early 2015 Logic Board Assembly Replacement
단지 전제 조건
이 안내서는 다른 가이드의 선행 작업으로 사용하기 위한 것입니다. 그 자체로는 불완전합니다.
필요한 것
  1. MacBook Pro 13" Retina Display Early 2015 Logic Board Assembly Replacement, Logic Board Assembly: 1 단계, 이미지 1/2 MacBook Pro 13" Retina Display Early 2015 Logic Board Assembly Replacement, Logic Board Assembly: 1 단계, 이미지 2/2
    • Remove the two 2.1 mm T5 Torx screws securing the I/O board cable bracket to the logic board.
    • Remove the I/O board cable bracket.
  2. MacBook Pro 13" Retina Display Early 2015 Logic Board Assembly Replacement: 2 단계, 이미지 1/2 MacBook Pro 13" Retina Display Early 2015 Logic Board Assembly Replacement: 2 단계, 이미지 2/2
    • Use the flat end of a spudger to pop the I/O board connector straight up off its socket on the logic board.
    • Be careful to only pry up on the I/O board cable, not on the socket itself or you risk damaging your logic board.
  3. MacBook Pro 13" Retina Display Early 2015 Logic Board Assembly Replacement: 3 단계, 이미지 1/2 MacBook Pro 13" Retina Display Early 2015 Logic Board Assembly Replacement: 3 단계, 이미지 2/2
    • Lift the logic board end of the I/O board cable straight up to bend it out of the way.
    • To avoid damage to the cable, fold only at the bend in the I/O board end of the cable.
  4. MacBook Pro 13" Retina Display Early 2015 Logic Board Assembly Replacement: 4 단계, 이미지 1/2 MacBook Pro 13" Retina Display Early 2015 Logic Board Assembly Replacement: 4 단계, 이미지 2/2
    • Use the tip of a spudger to lift the right speaker connector straight up out of its socket on the logic board.
  5. MacBook Pro 13" Retina Display Early 2015 Logic Board Assembly Replacement: 5 단계, 이미지 1/2 MacBook Pro 13" Retina Display Early 2015 Logic Board Assembly Replacement: 5 단계, 이미지 2/2
    • With the tip of a spudger, push on either side of the I/O board connector to walk it out of its socket on the logic board.
  6. MacBook Pro 13" Retina Display Early 2015 Logic Board Assembly Replacement: 6 단계, 이미지 1/3 MacBook Pro 13" Retina Display Early 2015 Logic Board Assembly Replacement: 6 단계, 이미지 2/3 MacBook Pro 13" Retina Display Early 2015 Logic Board Assembly Replacement: 6 단계, 이미지 3/3
    • Use the flat end of a spudger to disconnect the keyboard backlight cable and bend it up out of the way of the logic board.
  7. MacBook Pro 13" Retina Display Early 2015 Logic Board Assembly Replacement: 7 단계, 이미지 1/3 MacBook Pro 13" Retina Display Early 2015 Logic Board Assembly Replacement: 7 단계, 이미지 2/3 MacBook Pro 13" Retina Display Early 2015 Logic Board Assembly Replacement: 7 단계, 이미지 3/3
    • Grab the black plastic tab to flip the display cable connector open and pull it straight out of its socket on the logic board.
  8. MacBook Pro 13" Retina Display Early 2015 Logic Board Assembly Replacement: 8 단계, 이미지 1/2 MacBook Pro 13" Retina Display Early 2015 Logic Board Assembly Replacement: 8 단계, 이미지 2/2
    • Carefully pull the DC-In board connector straight out of its socket on the logic board.
  9. MacBook Pro 13" Retina Display Early 2015 Logic Board Assembly Replacement: 9 단계, 이미지 1/3 MacBook Pro 13" Retina Display Early 2015 Logic Board Assembly Replacement: 9 단계, 이미지 2/3 MacBook Pro 13" Retina Display Early 2015 Logic Board Assembly Replacement: 9 단계, 이미지 3/3
    • Wedge the flat end of a spudger under the left speaker cable near the connector and lift it straight up out of its socket and fold it out of the way.
  10. MacBook Pro 13" Retina Display Early 2015 Logic Board Assembly Replacement: 10 단계, 이미지 1/2 MacBook Pro 13" Retina Display Early 2015 Logic Board Assembly Replacement: 10 단계, 이미지 2/2
    • If necessary, peel back any tape covering the microphone cable ZIF connector.
  11. MacBook Pro 13" Retina Display Early 2015 Logic Board Assembly Replacement: 11 단계, 이미지 1/3 MacBook Pro 13" Retina Display Early 2015 Logic Board Assembly Replacement: 11 단계, 이미지 2/3 MacBook Pro 13" Retina Display Early 2015 Logic Board Assembly Replacement: 11 단계, 이미지 3/3
    • Use the tip of a spudger to flip the retaining tab on the microphone cable ZIF connector.
    • Pull the microphone cable out of its socket on the logic board.
  12. MacBook Pro 13" Retina Display Early 2015 Logic Board Assembly Replacement: 12 단계, 이미지 1/3 MacBook Pro 13" Retina Display Early 2015 Logic Board Assembly Replacement: 12 단계, 이미지 2/3 MacBook Pro 13" Retina Display Early 2015 Logic Board Assembly Replacement: 12 단계, 이미지 3/3
    • If necessary, peel back any tape covering the keyboard cable connector.
    • Use the tip of a spudger to flip the retaining tab on the ZIF connector.
  13. MacBook Pro 13" Retina Display Early 2015 Logic Board Assembly Replacement: 13 단계, 이미지 1/2 MacBook Pro 13" Retina Display Early 2015 Logic Board Assembly Replacement: 13 단계, 이미지 2/2
    • Pull the keyboard cable straight out of its ZIF socket on the logic board.
  14. MacBook Pro 13" Retina Display Early 2015 Logic Board Assembly Replacement: 14 단계, 이미지 1/3 MacBook Pro 13" Retina Display Early 2015 Logic Board Assembly Replacement: 14 단계, 이미지 2/3 MacBook Pro 13" Retina Display Early 2015 Logic Board Assembly Replacement: 14 단계, 이미지 3/3
    • Use the flat end of a spudger to pop the trackpad connector straight up off its socket on the logic board.
    • Fold the cable out back over the battery to clear the way for the logic board.
  15. MacBook Pro 13" Retina Display Early 2015 Logic Board Assembly Replacement: 15 단계, 이미지 1/1
    • Remove the five 3.5 mm T5 Torx screws securing the logic board to the upper case.
  16. MacBook Pro 13" Retina Display Early 2015 Logic Board Assembly Replacement: 16 단계, 이미지 1/3 MacBook Pro 13" Retina Display Early 2015 Logic Board Assembly Replacement: 16 단계, 이미지 2/3 MacBook Pro 13" Retina Display Early 2015 Logic Board Assembly Replacement: 16 단계, 이미지 3/3
    • Lift the processor end of the logic board up slightly and pull it toward the fan recess to free the ports from the edge of the upper case.
    • Remove the logic board.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Sam Goldheart
회원 가입일: 10/18/12
465,602 평판
안내서 538개 작성하였습니다
iFixit iFixit 회원
Staff
135 회원들
안내서 16,718개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 175
