주요 콘텐츠로 건너뛰기
MacBook Pro 13" Retina Display Early 2015 Trackpad Cable Replacement
단지 전제 조건
이 안내서는 다른 가이드의 선행 작업으로 사용하기 위한 것입니다. 그 자체로는 불완전합니다.
필요한 것
  1. MacBook Pro 13" Retina Display Early 2015 Trackpad Cable Replacement, Trackpad Cable: 1 단계, 이미지 1/2 MacBook Pro 13" Retina Display Early 2015 Trackpad Cable Replacement, Trackpad Cable: 1 단계, 이미지 2/2
    • Use the flat end of a spudger to pop the trackpad connector straight up off its socket on the logic board.
  2. MacBook Pro 13" Retina Display Early 2015 Trackpad Cable Replacement: 2 단계, 이미지 1/2 MacBook Pro 13" Retina Display Early 2015 Trackpad Cable Replacement: 2 단계, 이미지 2/2
    • Lift the trackpad cable up off the battery to separate it from the adhesive securing it.
    • Be careful not to damage the cable. If it doesn't peel up easily, apply a little heat from an iOpener, heat gun, or hair dryer to soften the adhesive, and try again.
  3. MacBook Pro 13" Retina Display Early 2015 Trackpad Cable Replacement: 3 단계, 이미지 1/3 MacBook Pro 13" Retina Display Early 2015 Trackpad Cable Replacement: 3 단계, 이미지 2/3 MacBook Pro 13" Retina Display Early 2015 Trackpad Cable Replacement: 3 단계, 이미지 3/3
    • If necessary, peel back any tape covering the trackpad cable connector.
    • Use the end of a spudger to flip the retaining tab on the ZIF connector.
  4. MacBook Pro 13" Retina Display Early 2015 Trackpad Cable Replacement: 4 단계, 이미지 1/2 MacBook Pro 13" Retina Display Early 2015 Trackpad Cable Replacement: 4 단계, 이미지 2/2
    • Pull the trackpad cable straight out of its ZIF socket on the trackpad control board.
  5. MacBook Pro 13" Retina Display Early 2015 Trackpad Cable Replacement: 5 단계, 이미지 1/1
    • Remove the single 3.7 mm T5 Torx screw securing the battery board to the upper case.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Sam Goldheart
회원 가입일: 10/18/12
465,854 평판
안내서 538개 작성하였습니다
iFixit iFixit 회원
Staff
135 회원들
안내서 17,198개 작성하였습니다
댓글 3개
Why remove the screw in step 5?
Ari Cooper - Davis - 답글
Yes @sam , why should you remove the screw in step 5? Is this a mistake?
lmdehaas - 답글
Step 5: Remove the single 3.7 mm T5 Torx screw.
Step 6: Re-screw single 3.7 mm T5 Torx screw.
David Grabowski - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 10
30일 전: 12
전체 시간: 1,794
