주요 콘텐츠로 건너뛰기
MacBook Pro 13" Retina Display Early 2015 Trackpad Cable Replacement
단지 전제 조건
이 안내서는 다른 가이드의 선행 작업으로 사용하기 위한 것입니다. 그 자체로는 불완전합니다.
필요한 것
  1. MacBook Pro 13" Retina Display Early 2015 Trackpad Cable Replacement, Trackpad Cable: 1 단계, 이미지 1/2 MacBook Pro 13" Retina Display Early 2015 Trackpad Cable Replacement, Trackpad Cable: 1 단계, 이미지 2/2
    • Use the flat end of a spudger to pop the trackpad connector straight up off its socket on the logic board.
  2. MacBook Pro 13" Retina Display Early 2015 Trackpad Cable Replacement: 2 단계, 이미지 1/2 MacBook Pro 13" Retina Display Early 2015 Trackpad Cable Replacement: 2 단계, 이미지 2/2
    • Lift the trackpad cable up off the battery to separate it from the adhesive securing it.
    • Be careful not to damage the cable. If it doesn't peel up easily, apply a little heat from an iOpener, heat gun, or hair dryer to soften the adhesive, and try again.
  3. MacBook Pro 13" Retina Display Early 2015 Trackpad Cable Replacement: 3 단계, 이미지 1/3 MacBook Pro 13" Retina Display Early 2015 Trackpad Cable Replacement: 3 단계, 이미지 2/3 MacBook Pro 13" Retina Display Early 2015 Trackpad Cable Replacement: 3 단계, 이미지 3/3
    • If necessary, peel back any tape covering the trackpad cable connector.
    • Use the end of a spudger to flip the retaining tab on the ZIF connector.
  4. MacBook Pro 13" Retina Display Early 2015 Trackpad Cable Replacement: 4 단계, 이미지 1/2 MacBook Pro 13" Retina Display Early 2015 Trackpad Cable Replacement: 4 단계, 이미지 2/2
    • Pull the trackpad cable straight out of its ZIF socket on the trackpad control board.
    • During reassembly, make sure that the retaining tab is in the up, "unlocked" position before you insert the cable into the socket.
  5. MacBook Pro 13" Retina Display Early 2015 Trackpad Cable Replacement: 5 단계, 이미지 1/1
    • Remove the single 3.7 mm T5 Torx screw securing the battery board to the upper case.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Sam Goldheart
회원 가입일: 10/18/12
465,744 평판
안내서 538개 작성하였습니다
iFixit iFixit 회원
Staff
135 회원들
안내서 16,816개 작성하였습니다
댓글 3개
Why remove the screw in step 5?
Ari Cooper - Davis - 답글
Yes @sam , why should you remove the screw in step 5? Is this a mistake?
lmdehaas - 답글
Step 5: Remove the single 3.7 mm T5 Torx screw.
Step 6: Re-screw single 3.7 mm T5 Torx screw.
David Grabowski - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 1,782
