이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
Use this guide to replace the LCD cable connected inside the hinge of your MacBook Pro Retina Display Assembly.
필요한 것
이 단계에 사용된 도구:Magnetic Project Mat$19.95
Remove the following ten screws securing the lower case to the upper case:
Two 2.3 mm P5 Pentalobe screws
Eight 3.0 mm P5 Pentalobe screws
Grasp the Interposer with tweezers.
Lift the Interposer off the logic board and remove it.
Use the tip of a spudger to push the iSight camera cable connector straight away from its socket on the logic board.
Use the flat end of a spudger to pry and disconnect the three antenna cable connectors from the AirPort board.
The three cables are coded with black sleeves of different lengths. During reassembly:
Connect the long-sleeved cable to the socket closest to the ports.
The short-sleeved cable connects next to the screw.
The remaining cable has no sleeve, and connects in the last empty socket, next to the fan.
Grab the black pull tab secured to the display data cable lock and rotate it toward the DC-In side of the computer.
Pull the display data cable straight out of its socket on the logic board.
With the display facing towards you and the plastic clutch cover down, grab the clutch cover and slide it all the way to the right, towards the hinge.
Lift the plastic cover from the bottom and remove it from the display.
다른 4명이 해당 안내서를 완성하였습니다.
