이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
Prereq only for upper case.
필요한 것
For this step, it is recommended to use a heat gun or hair dryer to soften the adhesive securing the microphone assembly to the upper case. You may be able to remove it without doing so, but will risk damaging the microphone cable.
With the heat gun set to low, heat the microphone assembly to loosen the adhesive attaching it to the upper case.
거의 끝나갑니다!
결론
