이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
For this step, it is recommended to use a heat gun or hair dryer to soften the adhesive securing the microphone assembly to the upper case. You may be able to remove it without doing so, but will risk damaging the microphone cable.
With the heat gun set to low, heat the microphone assembly to loosen the adhesive attaching it to the upper case.
Use the tip of a spudger to remove the piece of tape covering one of two microphones.
Grasp the piece of tape with a pair of tweezers and remove it.
Repeat the same procedure as the previous step to remove the tape covering the second microphone.
Wedge the tip of a spudger underneath the microphone assembly cable.
Run the spudger up along the bottom of the microphone assembly cable to separate it from the upper case.
Gently wedge the tip of a spudger underneath the second microphone and push inwards to loosen the adhesive.
