이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
Use this guide to replace the right fan.
필요한 것
이 단계에 사용된 도구:Magnetic Project Mat$19.95
Remove the following ten screws securing the lower case to the upper case:
Two 2.3 mm P5 Pentalobe screws
Eight 3.0 mm P5 Pentalobe screws
Grasp the Interposer with tweezers.
Lift the Interposer off the logic board and remove it.
Remove the following screws securing the heat sink to the logic board assembly:
One 2.4 mm Phillips #00 screw
One 3.4 mm T5 Torx screw
Four 2.7 mm T5 Torx screws
Use the flat end of a spudger to pry the right side of the I/O board data cable connector up off its socket on the I/O board.
Use the tip of a spudger to push the iSight camera cable connector straight away from its socket on the logic board.
Use the tip of a spudger to flip up the retaining flap on the right fan ribbon cable ZIF socket.
Pull the right fan ribbon cable straight out of its socket on the logic board.
다른 7명이 해당 안내서를 완성하였습니다.
