주요 콘텐츠로 건너뛰기
MacBook Pro 13" Retina Display Late 2012 Right Speaker Replacement
필요한 것
  1. MacBook Pro 13" Retina Display Late 2012 Right Speaker Replacement, Lower Case: 1 단계, 이미지 1/1
    이 단계에 사용된 도구:
    Magnetic Project Mat
    $19.95
    구매
    • Two 2.3 mm P5 Pentalobe screws
    • Eight 3.0 mm P5 Pentalobe screws
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your device.
  2. MacBook Pro 13" Retina Display Late 2012 Right Speaker Replacement: 2 단계, 이미지 1/1
    • Wedge your fingers between the upper case and the lower case.
    • Gently pull the lower case away from the upper case.
  3. MacBook Pro 13" Retina Display Late 2012 Right Speaker Replacement: 3 단계, 이미지 1/3 MacBook Pro 13" Retina Display Late 2012 Right Speaker Replacement: 3 단계, 이미지 2/3 MacBook Pro 13" Retina Display Late 2012 Right Speaker Replacement: 3 단계, 이미지 3/3
    • During reassembly, gently push down the center of the lower case to reattach the two plastic clips.
    • The lower case is connected to the upper case at the center, with two plastic clips.
  4. MacBook Pro 13" Retina Display Late 2012 Right Speaker Replacement, Battery Connector: 4 단계, 이미지 1/1
    • Remove the plastic cover adhered to the battery contact board.
  5. MacBook Pro 13" Retina Display Late 2012 Right Speaker Replacement: 5 단계, 이미지 1/1
    • Remove the following screws securing the battery connector board to the logic board:
    • Two 2.8 mm T6 Torx screws
    • One 7.0 mm T6 Torx shouldered screw
  6. MacBook Pro 13" Retina Display Late 2012 Right Speaker Replacement: 6 단계, 이미지 1/2 MacBook Pro 13" Retina Display Late 2012 Right Speaker Replacement: 6 단계, 이미지 2/2
    • Use tweezers to remove the small plastic cover located near the bottom right of the battery connector board.
  7. MacBook Pro 13" Retina Display Late 2012 Right Speaker Replacement: 7 단계, 이미지 1/1
    • Remove the wide head 6.4 mm T6 Torx screw securing the battery connector to the logic board assembly.
  8. MacBook Pro 13" Retina Display Late 2012 Right Speaker Replacement: 8 단계, 이미지 1/2 MacBook Pro 13" Retina Display Late 2012 Right Speaker Replacement: 8 단계, 이미지 2/2
    • Carefully lift the battery connector board up off the logic board.
    • It is recommended to bend the battery cables just slightly, to keep the board suspended up above the logic board and out of the way.
    • Do not fold the board completely over, or crease the cables, as this may damage the battery.
  9. MacBook Pro 13" Retina Display Late 2012 Right Speaker Replacement, Battery Contact Board: 9 단계, 이미지 1/2 MacBook Pro 13" Retina Display Late 2012 Right Speaker Replacement, Battery Contact Board: 9 단계, 이미지 2/2
    • Grasp the Interposer with tweezers.
    • An interposer is the name for an interface that links one electrical connection to another. In this repair, it is the board connecting the battery to logic board.
    • Lift the Interposer off the logic board and remove it.
    • Removing this board will ensure that the battery remains disconnected throughout your repair, preventing your computer from accidentally powering on. It's also a good idea to take it out so it doesn't fall out unexpectedly.
  10. MacBook Pro 13" Retina Display Late 2012 Right Speaker Replacement, I/O Board Data Cable: 10 단계, 이미지 1/2 MacBook Pro 13" Retina Display Late 2012 Right Speaker Replacement, I/O Board Data Cable: 10 단계, 이미지 2/2
    • Use the flat end of a spudger to pry the right side of the I/O board data cable connector up off its socket on the I/O board.
    • When prying the I/O board data cable connector from its socket, make sure to pry the connector itself and not the socket. Prying the socket may cause irreversible damage to the I/O board.
  11. MacBook Pro 13" Retina Display Late 2012 Right Speaker Replacement: 11 단계, 이미지 1/2 MacBook Pro 13" Retina Display Late 2012 Right Speaker Replacement: 11 단계, 이미지 2/2
    • Wedge the flat end of a spudger beneath the left side of the I/O board data cable connector.
    • Gently twist the spudger to disconnect the I/O board data cable connector from its socket on the logic board.
  12. MacBook Pro 13" Retina Display Late 2012 Right Speaker Replacement: 12 단계, 이미지 1/1
    • Lift and remove the I/O board data cable from the MacBook Pro.
  13. MacBook Pro 13" Retina Display Late 2012 Right Speaker Replacement, Right Speaker: 13 단계, 이미지 1/3 MacBook Pro 13" Retina Display Late 2012 Right Speaker Replacement, Right Speaker: 13 단계, 이미지 2/3 MacBook Pro 13" Retina Display Late 2012 Right Speaker Replacement, Right Speaker: 13 단계, 이미지 3/3
    • Use the flat end of a spudger to pry the SSD cable connector up from its socket on the logic board.
    • Move the SSD cable connector out of the way.
  14. MacBook Pro 13" Retina Display Late 2012 Right Speaker Replacement: 14 단계, 이미지 1/2 MacBook Pro 13" Retina Display Late 2012 Right Speaker Replacement: 14 단계, 이미지 2/2
    • Wedge the flat end of a spudger beneath the right speaker cable connector.
    • Gently pry the right speaker cable connector up off from its socket on the logic board.
    • Be sure you are prying up on the connector, not the socket itself.
  15. MacBook Pro 13" Retina Display Late 2012 Right Speaker Replacement: 15 단계, 이미지 1/2 MacBook Pro 13" Retina Display Late 2012 Right Speaker Replacement: 15 단계, 이미지 2/2
    • Use a T5 Torx driver to remove the following screws securing the right speaker to the upper case:
    • Two black 6.8 mm screws
    • One silver 6.3 mm screw
    • The silver screw (in the corner) may be covered with a foam pad. If so, use your tweezers to peel it up and remove it.
  16. MacBook Pro 13" Retina Display Late 2012 Right Speaker Replacement: 16 단계, 이미지 1/2 MacBook Pro 13" Retina Display Late 2012 Right Speaker Replacement: 16 단계, 이미지 2/2
    • Lift and remove the right speaker out of the upper case.
    • If necessary, de-route the right speaker cable from its channel in the upper case.
결론
다른 33명이 해당 안내서를 완성하였습니다.
Walter Galan
694,676 평판
안내서 1,203개 작성하였습니다
댓글 5개
Thanks for the steps, it worked. But now I am getting Wi-Fi- No hardware installed and Bluetooth Not available error
Divakar Jayaraman - 답글
it worked but the cam is not working now :(
I was able to fix the right speaker using the solvent used to remove the battery provided by iFixit.
Peter-Paul van Beekum - 답글
Thank you very much for the walkthrough. No problems to follow at all. Everything worked as a charm.
timofej.se - 답글
Thanks very much for the walkthrough. No problems at all. Everything working fine afterwards.
Vaughan Butler - 답글
댓글 쓰기
조회 통계:
24 시간 전: 5
7일 전: 27
30일 전: 111
전체 시간: 23,129
