주요 콘텐츠로 건너뛰기
MacBook Pro 13" Retina Display Late 2013 AirPort Board Replacement
필요한 것
    • Two 2.3 mm P5 Pentalobe screws
    • Eight 3.0 mm P5 Pentalobe screws
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your device.
  1. MacBook Pro 13" Retina Display Late 2013 AirPort Board Replacement: 2 단계, 이미지 1/1
    • Wedge your fingers between the upper case and the lower case.
    • Gently pull the lower case away from the upper case to remove it.
  2. MacBook Pro 13" Retina Display Late 2013 AirPort Board Replacement: 3 단계, 이미지 1/2 MacBook Pro 13" Retina Display Late 2013 AirPort Board Replacement: 3 단계, 이미지 2/2
    • The lower case is connected to the upper case with two plastic clips near its center.
    • During reassembly, gently push down the center of the lower case to reattach the two plastic clips.
  3. MacBook Pro 13" Retina Display Late 2013 AirPort Board Replacement, Battery Connector: 4 단계, 이미지 1/1
    • If necessary, remove the plastic cover adhered to the battery contact board.
  4. MacBook Pro 13" Retina Display Late 2013 AirPort Board Replacement: 5 단계, 이미지 1/2 MacBook Pro 13" Retina Display Late 2013 AirPort Board Replacement: 5 단계, 이미지 2/2
    • Use the flat end of a spudger to lift the battery connector straight up out of its socket on the logic board.
    • Be sure you lift up only on the connector itself, not the socket, or you risk permanent damage to the logic board.
  5. MacBook Pro 13" Retina Display Late 2013 AirPort Board Replacement: 6 단계, 이미지 1/1
    • Bend the battery connector up out of the way to prevent accidental contact with its socket during your repair.
  6. MacBook Pro 13" Retina Display Late 2013 AirPort Board Replacement, AirPort Board: 7 단계, 이미지 1/3 MacBook Pro 13" Retina Display Late 2013 AirPort Board Replacement, AirPort Board: 7 단계, 이미지 2/3 MacBook Pro 13" Retina Display Late 2013 AirPort Board Replacement, AirPort Board: 7 단계, 이미지 3/3
    • Wedge the tip of a spudger underneath each of the antenna cables, near their connectors and pry up to disconnect them from the AirPort board.
    • The three cables are coded with black sleeves of different lengths. During reassembly:
    • Connect the long-sleeved cable to the center socket.
    • The short-sleeved cable connects next to the screw.
    • The remaining cable has no sleeve, and connects in the last empty socket, next to the fan.
  7. MacBook Pro 13" Retina Display Late 2013 AirPort Board Replacement: 8 단계, 이미지 1/1
    • Remove the single 2.7 mm T5 Torx screw securing the AirPort board to the I/O board.
  8. MacBook Pro 13" Retina Display Late 2013 AirPort Board Replacement: 9 단계, 이미지 1/3 MacBook Pro 13" Retina Display Late 2013 AirPort Board Replacement: 9 단계, 이미지 2/3 MacBook Pro 13" Retina Display Late 2013 AirPort Board Replacement: 9 단계, 이미지 3/3
    • Lift the free end of the AirPort board up slightly and pull it straight out of its socket on the logic board.
결론
다른 17명이 해당 안내서를 완성하였습니다.
Sam Goldheart
회원 가입일: 10/18/12
458,619 평판
안내서 538개 작성하였습니다
iFixit iFixit 회원
Community
141 회원들
안내서 17,643개 작성하였습니다
2 댓글
What happened when it says "no wifi hardware detect " after replacing airport card?
Young Kwok - 답글
If you aware how to replace wi-fi antenna ?
eyehan eyehan - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 14
30일 전: 116
전체 시간: 21,698
