주요 콘텐츠로 건너뛰기
MacBook Pro 13" Retina Display Late 2013 Left Speaker Replacement
필요한 것
  1. MacBook Pro 13" Retina Display Late 2013 Left Speaker Replacement, Lower Case: 1 단계, 이미지 1/1
    이 단계에 사용된 도구:
    Magnetic Project Mat
    $19.95
    구매
    • Two 2.3 mm P5 Pentalobe screws
    • Eight 3.0 mm P5 Pentalobe screws
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your device.
  2. MacBook Pro 13" Retina Display Late 2013 Left Speaker Replacement: 2 단계, 이미지 1/1
    • Wedge your fingers between the upper case and the lower case.
    • Gently pull the lower case away from the upper case to remove it.
  3. MacBook Pro 13" Retina Display Late 2013 Left Speaker Replacement: 3 단계, 이미지 1/2 MacBook Pro 13" Retina Display Late 2013 Left Speaker Replacement: 3 단계, 이미지 2/2
    • The lower case is connected to the upper case with two plastic clips near its center.
    • During reassembly, gently push down the center of the lower case to reattach the two plastic clips.
  4. MacBook Pro 13" Retina Display Late 2013 Left Speaker Replacement, Battery Connector: 4 단계, 이미지 1/1
    • If necessary, remove the plastic cover adhered to the battery contact board.
  5. MacBook Pro 13" Retina Display Late 2013 Left Speaker Replacement: 5 단계, 이미지 1/2 MacBook Pro 13" Retina Display Late 2013 Left Speaker Replacement: 5 단계, 이미지 2/2
    • Use the flat end of a spudger to lift the battery connector straight up out of its socket on the logic board.
    • Be sure you lift up only on the connector itself, not the socket, or you risk permanent damage to the logic board.
  6. MacBook Pro 13" Retina Display Late 2013 Left Speaker Replacement: 6 단계, 이미지 1/1
    • Bend the battery connector up out of the way to prevent accidental contact with its socket during your repair.
  7. MacBook Pro 13" Retina Display Late 2013 Left Speaker Replacement, Left Speaker: 7 단계, 이미지 1/2 MacBook Pro 13" Retina Display Late 2013 Left Speaker Replacement, Left Speaker: 7 단계, 이미지 2/2
    • Insert the tip of a spudger under the left speaker cable near the connector and lift it up out of its socket on the logic board.
  8. MacBook Pro 13" Retina Display Late 2013 Left Speaker Replacement: 8 단계, 이미지 1/1
    • Remove the following screws securing the left speaker to the upper case:
    • One 5.7 mm T5 Torx screw
    • One 6.5 mm T5 Torx screw
    • One 3.8 mm T5 Torx screw
  9. MacBook Pro 13" Retina Display Late 2013 Left Speaker Replacement: 9 단계, 이미지 1/3 MacBook Pro 13" Retina Display Late 2013 Left Speaker Replacement: 9 단계, 이미지 2/3 MacBook Pro 13" Retina Display Late 2013 Left Speaker Replacement: 9 단계, 이미지 3/3
    • Lift the corner of the left speaker up and slide it out around the battery to remove it from the upper case.
    • Be careful not to snag the speaker cable on the screw hole post in the side of the case.
결론
다른 83명이 해당 안내서를 완성하였습니다.
Sam Goldheart
회원 가입일: 10/18/12
465,741 평판
안내서 538개 작성하였습니다
iFixit iFixit 회원
Staff
135 회원들
안내서 16,767개 작성하였습니다
댓글 16개
A very straightforward repair. Thanks for the excellent instructions!
Andrew - 답글
is the same process for the right speaker? thank you very much Sam Lionheart!
Tonino - 답글
Pretty much, there's another cable to disconnect, but we have a whole guide for the right speaker, too! Best of luck!
Sam Goldheart -
Hi! Are the L/R speakers compatible with the 13" Early 2015 models?
fylungster - 답글
Great guide. I was able to dismantle the speaker and fixed the blown left speaker. Fit it back and it worked. Now, i’ll do that for the right speaker.
iamleongch - 답글
댓글 쓰기
조회 통계:
24 시간 전: 10
7일 전: 113
30일 전: 359
전체 시간: 75,733
