주요 콘텐츠로 건너뛰기
MacBook Pro 13" Retina Display Late 2013 MagSafe DC-In Board Replacement
필요한 것
  1. MacBook Pro 13" Retina Display Late 2013 MagSafe DC-In Board Replacement, Lower Case: 1 단계, 이미지 1/1
    이 단계에 사용된 도구:
    Magnetic Project Mat
    $19.95
    구매
    • Two 2.3 mm P5 Pentalobe screws
    • Eight 3.0 mm P5 Pentalobe screws
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your device.
  2. MacBook Pro 13" Retina Display Late 2013 MagSafe DC-In Board Replacement: 2 단계, 이미지 1/1
    • Wedge your fingers between the upper case and the lower case.
    • Gently pull the lower case away from the upper case to remove it.
  3. MacBook Pro 13" Retina Display Late 2013 MagSafe DC-In Board Replacement: 3 단계, 이미지 1/2 MacBook Pro 13" Retina Display Late 2013 MagSafe DC-In Board Replacement: 3 단계, 이미지 2/2
    • The lower case is connected to the upper case with two plastic clips near its center.
    • During reassembly, gently push down the center of the lower case to reattach the two plastic clips.
  4. MacBook Pro 13" Retina Display Late 2013 MagSafe DC-In Board Replacement, Battery Connector: 4 단계, 이미지 1/1
    • If necessary, remove the plastic cover adhered to the battery contact board.
  5. MacBook Pro 13" Retina Display Late 2013 MagSafe DC-In Board Replacement: 5 단계, 이미지 1/2 MacBook Pro 13" Retina Display Late 2013 MagSafe DC-In Board Replacement: 5 단계, 이미지 2/2
    • Use the flat end of a spudger to lift the battery connector straight up out of its socket on the logic board.
    • Be sure you lift up only on the connector itself, not the socket, or you risk permanent damage to the logic board.
  6. MacBook Pro 13" Retina Display Late 2013 MagSafe DC-In Board Replacement: 6 단계, 이미지 1/1
    • Bend the battery connector up out of the way to prevent accidental contact with its socket during your repair.
  7. MacBook Pro 13" Retina Display Late 2013 MagSafe DC-In Board Replacement, MagSafe DC-In Board: 7 단계, 이미지 1/3 MacBook Pro 13" Retina Display Late 2013 MagSafe DC-In Board Replacement, MagSafe DC-In Board: 7 단계, 이미지 2/3 MacBook Pro 13" Retina Display Late 2013 MagSafe DC-In Board Replacement, MagSafe DC-In Board: 7 단계, 이미지 3/3
    • Grab the black plastic tab to flip the display cable connector open and pull it straight out of its socket on the logic board.
    • Pull in the direction of the cable, parallel to the logic board. Do not pull up.
  8. MacBook Pro 13" Retina Display Late 2013 MagSafe DC-In Board Replacement: 8 단계, 이미지 1/2 MacBook Pro 13" Retina Display Late 2013 MagSafe DC-In Board Replacement: 8 단계, 이미지 2/2
    • Pull the DC-In board connector straight out of its socket on the logic board.
  9. MacBook Pro 13" Retina Display Late 2013 MagSafe DC-In Board Replacement: 9 단계, 이미지 1/1
    • Remove the two 3.5 mm T5 Torx screws securing the MagSafe DC-In board to the upper case.
    • You may need to gently push the display cable out of the way to expose the screws.
  10. MacBook Pro 13" Retina Display Late 2013 MagSafe DC-In Board Replacement: 10 단계, 이미지 1/3 MacBook Pro 13" Retina Display Late 2013 MagSafe DC-In Board Replacement: 10 단계, 이미지 2/3 MacBook Pro 13" Retina Display Late 2013 MagSafe DC-In Board Replacement: 10 단계, 이미지 3/3
    • Use the MagSafe DC-In board cable to pull the board out and up from the upper case to remove it.
결론
다른 26명이 해당 안내서를 완성하였습니다.
Sam Goldheart
회원 가입일: 10/18/12
465,870 평판
안내서 538개 작성하였습니다
iFixit iFixit 회원
Staff
135 회원들
안내서 17,243개 작성하였습니다
댓글 7개
How can I know if the magsafe is not working ?
lpelaez - 답글
Thanks for great tutorial!
Yep, what are the signs of bad dc-in board?
When I plug in the charger, LED on magsafe connector doesn't light up.
AC Charger Information:
Connected: Yes
Revision: 0x0000
Family: 0x0000
Serial Number: 0x00000000
Charging: No
For some reason charging doesn't start, my battery has only 600 cycles on it.
Can you guys help?
P.S. I tried plugging other adapters thats working, same thing (
Olga Kolina - 답글
Did you ever get a solution? I got a new MacBook Pro and didn’t use this one for 2 months, then went to charge it and nothing happens! No light on the charger and the battery is totally dead! I’m going to replace this DC board and maybe the battery. Did you get yours working?
Billy May -
I Have replaced the battery and the machine still works under the power from the new battery but the LED won’t come on the magsafe charger. Now I have replaced the DC In board and still not charging. the charger works on the other Mac in the house. What could the issue be?
Christopher Culler - 답글
Will you have the replacement piece available anytime soon ?
hergas - 답글
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 46
30일 전: 182
전체 시간: 18,899
