주요 콘텐츠로 건너뛰기
MacBook Pro 13" Retina Display Mid 2014 Lower Case Replacement
필요한 것
    • Two 2.3 mm P5 Pentalobe screws
    • Eight 3.0 mm P5 Pentalobe screws
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your device.
  1. MacBook Pro 13" Retina Display Mid 2014 Lower Case Replacement: 2 단계, 이미지 1/1
    • Wedge your fingers between the upper case and the lower case.
    • Gently pull the lower case away from the upper case to remove it.
  2. MacBook Pro 13" Retina Display Mid 2014 Lower Case Replacement: 3 단계, 이미지 1/2 MacBook Pro 13" Retina Display Mid 2014 Lower Case Replacement: 3 단계, 이미지 2/2
    • The lower case is connected to the upper case with two plastic clips near its center.
    • During reassembly, gently push down the center of the lower case to reattach the two plastic clips.
결론
다른 18명이 해당 안내서를 완성하였습니다.
Sam Goldheart
회원 가입일: 10/18/12
457,237 평판
안내서 537개 작성하였습니다
iFixit iFixit 회원
Community
138 회원들
안내서 17,041개 작성하였습니다
댓글 한 개
Do i have to hear some "click" noise when reconnecting the plastic clips? I did gently push the middle of the lower case, but the clips did not reconnected (it was still easy to remove the lower case). Hence i just put screws back, and then little bit strongly push the lower case again, but there was no "click" noise eithe ... However, the bottom case is completely flat, so i suppose it is ok...
K4stan - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 27
30일 전: 113
전체 시간: 29,361
