소개
Use this guide to replace a faulty MagSafe DC-In board.
필요한 것
Remove the following ten screws securing the lower case to the upper case:
Two 2.3 mm P5 Pentalobe screws
Eight 3.0 mm P5 Pentalobe screws
Grab the black plastic tab to flip the display cable connector open and pull it straight out of its socket on the logic board.
Pull in the direction of the cable, parallel to the logic board. Do not pull up.
다른 27명이 해당 안내서를 완성하였습니다.
7 댓글
Thanks very much, took me 10 mins, A nice cheap and fast repair for my damaged MagSafe socket
Thank you for your guidance! Spent $30 on tools as opposed to hundreds and made a simple repair
Thank you ...just what we need !..
Mark White - 답글
