주요 콘텐츠로 건너뛰기
MacBook Pro 13" Retina Display Mid 2014 Right Speaker Replacement
필요한 것
    • Two 2.3 mm P5 Pentalobe screws
    • Eight 3.0 mm P5 Pentalobe screws
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your device.
  1. MacBook Pro 13" Retina Display Mid 2014 Right Speaker Replacement: 2 단계, 이미지 1/1
    • Wedge your fingers between the upper case and the lower case.
    • Gently pull the lower case away from the upper case to remove it.
  2. MacBook Pro 13" Retina Display Mid 2014 Right Speaker Replacement: 3 단계, 이미지 1/2 MacBook Pro 13" Retina Display Mid 2014 Right Speaker Replacement: 3 단계, 이미지 2/2
    • The lower case is connected to the upper case with two plastic clips near its center.
    • During reassembly, gently push down the center of the lower case to reattach the two plastic clips.
  3. MacBook Pro 13" Retina Display Mid 2014 Right Speaker Replacement, Battery Connector: 4 단계, 이미지 1/1
    • If necessary, remove the plastic cover adhered to the battery contact board.
  4. MacBook Pro 13" Retina Display Mid 2014 Right Speaker Replacement: 5 단계, 이미지 1/2 MacBook Pro 13" Retina Display Mid 2014 Right Speaker Replacement: 5 단계, 이미지 2/2
    • Use the flat end of a spudger to lift the battery connector straight up out of its socket on the logic board.
    • Be sure you lift up only on the connector itself, not the socket, or you risk permanent damage to the logic board.
  5. MacBook Pro 13" Retina Display Mid 2014 Right Speaker Replacement: 6 단계, 이미지 1/1
    • Bend the battery connector up out of the way to prevent accidental contact with its socket during your repair.
  6. MacBook Pro 13" Retina Display Mid 2014 Right Speaker Replacement, Right Speaker: 7 단계, 이미지 1/1
    • Remove the two 2.1 mm T5 Torx screws securing the logic board end of the I/O board cable bracket.
  7. MacBook Pro 13" Retina Display Mid 2014 Right Speaker Replacement: 8 단계, 이미지 1/1
    • Grasp the I/O board cable bracket with a pair of tweezers and remove it from the MacBook.
  8. MacBook Pro 13" Retina Display Mid 2014 Right Speaker Replacement: 9 단계, 이미지 1/2 MacBook Pro 13" Retina Display Mid 2014 Right Speaker Replacement: 9 단계, 이미지 2/2
    • Use the flat end of a spudger to pop the I/O board connector straight up off its socket on the logic board.
    • Be careful to only pry up on the I/O board cable, not on the socket itself or you risk damaging your logic board.
  9. MacBook Pro 13" Retina Display Mid 2014 Right Speaker Replacement: 10 단계, 이미지 1/2 MacBook Pro 13" Retina Display Mid 2014 Right Speaker Replacement: 10 단계, 이미지 2/2
    • Lift the logic board end of the I/O board cable straight up to bend it out of the way.
    • To avoid damage to the cable, fold only at the bend in the I/O board end of the cable.
  10. MacBook Pro 13" Retina Display Mid 2014 Right Speaker Replacement: 11 단계, 이미지 1/2 MacBook Pro 13" Retina Display Mid 2014 Right Speaker Replacement: 11 단계, 이미지 2/2
    • Carefully tuck the tip of a spudger under the right speaker cable near the connector and lift it up out of its socket on the logic board.
  11. MacBook Pro 13" Retina Display Mid 2014 Right Speaker Replacement: 12 단계, 이미지 1/3 MacBook Pro 13" Retina Display Mid 2014 Right Speaker Replacement: 12 단계, 이미지 2/3 MacBook Pro 13" Retina Display Mid 2014 Right Speaker Replacement: 12 단계, 이미지 3/3
    • Carefully peel the right speaker cable off the upper case.
  12. MacBook Pro 13" Retina Display Mid 2014 Right Speaker Replacement: 13 단계, 이미지 1/1
    • Remove the following screws securing the right speaker to the upper case:
    • One 5.7 mm T5 Torx screw
    • One 6.5 mm T5 Torx screw
    • One 3.8 mm T5 Torx screw
  13. MacBook Pro 13" Retina Display Mid 2014 Right Speaker Replacement: 14 단계, 이미지 1/3 MacBook Pro 13" Retina Display Mid 2014 Right Speaker Replacement: 14 단계, 이미지 2/3 MacBook Pro 13" Retina Display Mid 2014 Right Speaker Replacement: 14 단계, 이미지 3/3
    • Lift the right speaker from the cable end and pull it free from the case.
결론
다른 44명이 해당 안내서를 완성하였습니다.
Sam Goldheart
회원 가입일: 10/18/12
457,026 평판
안내서 537개 작성하였습니다
iFixit iFixit 회원
Community
140 회원들
안내서 16,861개 작성하였습니다
0 Comments
댓글 쓰기
조회 통계:
24 시간 전: 9
7일 전: 78
30일 전: 363
전체 시간: 31,858
