주요 콘텐츠로 건너뛰기
MacBook Pro 13" Touch Bar 2017 Lower Case Replacement
필요한 것
  1. MacBook Pro 13" Touch Bar 2017 Lower Case Replacement, Disable Auto Boot: 1 단계, 이미지 1/3 MacBook Pro 13" Touch Bar 2017 Lower Case Replacement, Disable Auto Boot: 1 단계, 이미지 2/3 MacBook Pro 13" Touch Bar 2017 Lower Case Replacement, Disable Auto Boot: 1 단계, 이미지 3/3
    • Before starting this procedure, you must disable your Mac's Auto Boot feature. Auto Boot powers on your Mac when you open the lid, and may be accidentally triggered during disassembly. Use this guide or follow the abbreviated instructions below to disable Auto Boot. This command may not work on all Macs.
    • Power on your Mac and launch Terminal.
    • Copy and paste the following command (or type it exactly) into Terminal:
    • sudo nvram AutoBoot=%00
    • Press [return]. If prompted, enter your administrator password and press [return] again. Note: Your return key may also be labeled ⏎ or "enter."
    • You can now safely power down your Mac and open the bottom case, without it accidentally powering on.
    • When your repair is complete and your Mac is successfully reassembled, re-enable Auto Boot with the following command:
    • sudo nvram AutoBoot=%03
  2. MacBook Pro 13" Touch Bar 2017 Lower Case Replacement, Remove the pentalobe screws: 2 단계, 이미지 1/1
    이 단계에 사용된 도구:
    Magnetic Project Mat
    $19.95
    구매
    • Before proceeding, unplug and power down your MacBook. Close the display and lay it on a soft surface, top-side down.
    • Use a P5 Pentalobe driver to remove the six screws securing the lower case:
    • Two 6.2 mm screws
    • Four 3.4 mm screws
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your device.
  3. MacBook Pro 13" Touch Bar 2017 Lower Case Replacement, Open a gap using a suction cup: 3 단계, 이미지 1/2 MacBook Pro 13" Touch Bar 2017 Lower Case Replacement, Open a gap using a suction cup: 3 단계, 이미지 2/2
    • Apply a suction handle to the lower case near the front-center area of the MacBook Pro.
    • Lift the suction handle to create a slight gap between the lower case and the chassis.
  4. MacBook Pro 13" Touch Bar 2017 Lower Case Replacement, Separate the clips: 4 단계, 이미지 1/3 MacBook Pro 13" Touch Bar 2017 Lower Case Replacement, Separate the clips: 4 단계, 이미지 2/3 MacBook Pro 13" Touch Bar 2017 Lower Case Replacement, Separate the clips: 4 단계, 이미지 3/3
    • Insert one corner of an opening pick into the space between the lower case and the chassis.
    • Slide the opening pick around the nearest corner and halfway up the side of the case.
    • This releases the first of the hidden clips securing the lower case to the chassis. You should feel and hear the clip pop free.
  5. MacBook Pro 13" Touch Bar 2017 Lower Case Replacement: 5 단계, 이미지 1/3 MacBook Pro 13" Touch Bar 2017 Lower Case Replacement: 5 단계, 이미지 2/3 MacBook Pro 13" Touch Bar 2017 Lower Case Replacement: 5 단계, 이미지 3/3
    • Repeat the previous step on the opposite side, sliding your opening pick under the lower case and up the side to pop the second clip free.
  6. MacBook Pro 13" Touch Bar 2017 Lower Case Replacement: 6 단계, 이미지 1/3 MacBook Pro 13" Touch Bar 2017 Lower Case Replacement: 6 단계, 이미지 2/3 MacBook Pro 13" Touch Bar 2017 Lower Case Replacement: 6 단계, 이미지 3/3
    • Insert your opening pick once again under the front edge of the lower case, near one of the two centermost screw holes.
    • Give the pick a firm twist to pop free the third clip securing the lower case to the chassis.
    • Repeat this procedure near the other of the two centermost screw holes, popping the fourth clip free.
  7. MacBook Pro 13" Touch Bar 2017 Lower Case Replacement: 7 단계, 이미지 1/3 MacBook Pro 13" Touch Bar 2017 Lower Case Replacement: 7 단계, 이미지 2/3 MacBook Pro 13" Touch Bar 2017 Lower Case Replacement: 7 단계, 이미지 3/3
    • Pull the lower case firmly towards the front of the MacBook (away from the hinge area) to separate the last of the clips securing the lower case.
    • Pull first at one corner, then the other.
    • Pull to the side—not up.
    • This can require a lot of force.
  8. MacBook Pro 13" Touch Bar 2017 Lower Case Replacement, Remove the lower case: 8 단계, 이미지 1/3 MacBook Pro 13" Touch Bar 2017 Lower Case Replacement, Remove the lower case: 8 단계, 이미지 2/3 MacBook Pro 13" Touch Bar 2017 Lower Case Replacement, Remove the lower case: 8 단계, 이미지 3/3
    • Remove the lower case.
    • To reinstall the lower case:
    • Set it in place and align the sliding clips near the display hinge. Press down and slide the cover toward the hinge. It should stop sliding as the clips engage.
    • When the sliding clips are fully engaged and the lower case looks correctly aligned, press down firmly on the lower case to engage the four hidden clips underneath. You should feel and hear them snap into place.
결론
다른 18명이 해당 안내서를 완성하였습니다.
Jeff Suovanen
회원 가입일: 08/06/13
427,796 평판
안내서 259개 작성하였습니다
iFixit iFixit 회원
Staff
135 회원들
안내서 16,718개 작성하였습니다
댓글 2개
Before step 7: if you removed the clips properly, the panel will move up by quite a bit. make sure it's not flat when trying to pull, because that mean you didn't loosen the clips enough
Ali - 답글
Merci pource très bon tutoriel démontage du couvercle sans problème.
Fajardo - 답글
댓글 쓰기
조회 통계:
24 시간 전: 11
7일 전: 82
30일 전: 341
전체 시간: 20,805
