주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
MacBook Pro 13" Touch Bar 2018 Left fan Replacement
필요한 것
  1. MacBook Pro 13" Touch Bar 2018 Left fan Replacement, Disable Auto Boot: 1 단계, 이미지 3개 중 1개 MacBook Pro 13" Touch Bar 2018 Left fan Replacement, Disable Auto Boot: 1 단계, 이미지 3개 중 2개 MacBook Pro 13" Touch Bar 2018 Left fan Replacement, Disable Auto Boot: 1 단계, 이미지 3개 중 3개
    • Before starting this procedure, you must disable your Mac's Auto Boot feature. Auto Boot powers on your Mac when you open the lid, and may be accidentally triggered during disassembly. Use this guide or follow the abbreviated instructions below to disable Auto Boot. This command may not work on all Macs.
    • Power on your Mac and launch Terminal.
    • Copy and paste the following command (or type it exactly) into Terminal:
    • 'sudo nvram AutoBoot=%00
    • Press [return]. If prompted, enter your administrator password and press [return] again. Note: Your return key may also be labeled ⏎ or "enter."
    • You can now safely power down your Mac and open the bottom case, without it accidentally powering on.
    • When your repair is complete and your Mac is successfully reassembled, re-enable Auto Boot with the following command (typed into Terminal, as shown above):
    • sudo nvram AutoBoot=%03
  2. MacBook Pro 13" Touch Bar 2018 Left fan Replacement, Remove the pentalobe screws: 2 단계, 이미지 1개 중 1개
    • Before proceeding, unplug and power down your MacBook. Close the display and lay it on a soft surface, top-side down.
    • Use a P5 Pentalobe driver to remove the six screws securing the lower case:
    • Two 6.2 mm screws
    • Four 3.4 mm screws
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your device.
  3. MacBook Pro 13" Touch Bar 2018 Left fan Replacement, Open a gap using a suction cup: 3 단계, 이미지 2개 중 1개 MacBook Pro 13" Touch Bar 2018 Left fan Replacement, Open a gap using a suction cup: 3 단계, 이미지 2개 중 2개
    • Apply a suction handle to the lower case near the front-center area of the MacBook Pro.
    • Lift the suction handle to create a slight gap between the lower case and the chassis.
  4. MacBook Pro 13" Touch Bar 2018 Left fan Replacement, Separate the clips: 4 단계, 이미지 3개 중 1개 MacBook Pro 13" Touch Bar 2018 Left fan Replacement, Separate the clips: 4 단계, 이미지 3개 중 2개 MacBook Pro 13" Touch Bar 2018 Left fan Replacement, Separate the clips: 4 단계, 이미지 3개 중 3개
    • Insert one corner of an opening pick into the space between the lower case and the chassis.
    • Slide the opening pick around the nearest corner and halfway up the side of the case.
    • This releases the first of the hidden clips securing the lower case to the chassis. You should feel and hear the clip pop free.
  5. MacBook Pro 13" Touch Bar 2018 Left fan Replacement: 5 단계, 이미지 3개 중 1개 MacBook Pro 13" Touch Bar 2018 Left fan Replacement: 5 단계, 이미지 3개 중 2개 MacBook Pro 13" Touch Bar 2018 Left fan Replacement: 5 단계, 이미지 3개 중 3개
    • Repeat the previous step on the opposite side, sliding your opening pick under the lower case and up the side to pop the second clip free.
  6. MacBook Pro 13" Touch Bar 2018 Left fan Replacement: 6 단계, 이미지 3개 중 1개 MacBook Pro 13" Touch Bar 2018 Left fan Replacement: 6 단계, 이미지 3개 중 2개 MacBook Pro 13" Touch Bar 2018 Left fan Replacement: 6 단계, 이미지 3개 중 3개
    • Insert your opening pick once again under the front edge of the lower case, near one of the two centermost screw holes.
    • Give the pick a firm twist to pop free the third clip securing the lower case to the chassis.
    • Repeat this procedure near the other of the two centermost screw holes, popping the fourth clip free.
  7. MacBook Pro 13" Touch Bar 2018 Left fan Replacement: 7 단계, 이미지 3개 중 1개 MacBook Pro 13" Touch Bar 2018 Left fan Replacement: 7 단계, 이미지 3개 중 2개 MacBook Pro 13" Touch Bar 2018 Left fan Replacement: 7 단계, 이미지 3개 중 3개
    • Pull the lower case firmly towards the front of the MacBook (away from the hinge area) to separate the last of the clips securing the lower case.
    • Pull first at one corner, then the other.
    • Pull to the side—not up.
    • This can require a lot of force.
  8. MacBook Pro 13" Touch Bar 2018 Left fan Replacement, Remove the lower case: 8 단계, 이미지 1개 중 1개
    • Remove the lower case.
  9. MacBook Pro 13" Touch Bar 2018 Left fan Replacement, Uncover the battery connector: 9 단계, 이미지 2개 중 1개 MacBook Pro 13" Touch Bar 2018 Left fan Replacement, Uncover the battery connector: 9 단계, 이미지 2개 중 2개
    • Carefully peel up the large piece of tape covering the battery connector, on the edge of the logic board nearest the battery.
    • Remove the tape.
  10. MacBook Pro 13" Touch Bar 2018 Left fan Replacement: 10 단계, 이미지 2개 중 1개 MacBook Pro 13" Touch Bar 2018 Left fan Replacement: 10 단계, 이미지 2개 중 2개
    • Gently peel back the small piece of tape covering the battery board data cable connector.
    • The tape is integrated into the ribbon cable and will not detach completely. Simply peel it back enough to access the connector.
  11. MacBook Pro 13" Touch Bar 2018 Left fan Replacement: 11 단계, 이미지 2개 중 1개 MacBook Pro 13" Touch Bar 2018 Left fan Replacement: 11 단계, 이미지 2개 중 2개
    • Disconnect the battery board data cable by sliding it out from its socket.
    • Slide parallel to the logic board, in the direction of the cable.
  12. MacBook Pro 13" Touch Bar 2018 Left fan Replacement: 12 단계, 이미지 2개 중 1개 MacBook Pro 13" Touch Bar 2018 Left fan Replacement: 12 단계, 이미지 2개 중 2개
    • Fold the battery board data cable to the side and out of the way.
  13. MacBook Pro 13" Touch Bar 2018 Left fan Replacement: 13 단계, 이미지 1개 중 1개
    • Use a T5 Torx driver to remove the 3.7 mm pancake screw securing the battery power connector.
  14. MacBook Pro 13" Touch Bar 2018 Left fan Replacement, Disconnect the battery: 14 단계, 이미지 2개 중 1개 MacBook Pro 13" Touch Bar 2018 Left fan Replacement, Disconnect the battery: 14 단계, 이미지 2개 중 2개
    • Use a spudger to gently lift the battery power connector, disconnecting the battery.
    • Lift the connector high enough so that it stays separated from its socket. If it accidentally makes contact during the course of your repair, it could damage your MacBook Pro.
  15. MacBook Pro 13" Touch Bar 2018 Left fan Replacement, Remove the trackpad connector screws: 15 단계, 이미지 1개 중 1개
    • Use a T3 Torx driver to remove the two 1.8 mm screws securing the trackpad cable connector bracket.
  16. MacBook Pro 13" Touch Bar 2018 Left fan Replacement: 16 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Remove the trackpad cable connector bracket with a pair of tweezers.
  17. MacBook Pro 13" Touch Bar 2018 Left fan Replacement: 17 단계, 이미지 2개 중 1개 MacBook Pro 13" Touch Bar 2018 Left fan Replacement: 17 단계, 이미지 2개 중 2개
    • Use a spudger to disconnect the trackpad ribbon cable by gently prying its connector straight up from the logic board.
  18. MacBook Pro 13" Touch Bar 2018 Left fan Replacement, Disconnect keyboard connector: 18 단계, 이미지 1개 중 1개
    • Use a T3 Torx driver to remove the two screws.
    • Two T3 Torx Screws.
  19. MacBook Pro 13" Touch Bar 2018 Left fan Replacement, Unplug Left speaker cables: 19 단계, 이미지 1개 중 1개
    • Carefully peel back the black tape to reveal the ZIF connector.
    • Unlatch the ZIF connector by flicking the arm on the connector upwards and carefully remove the cable from the connector by sliding it out.
    • Repeat this process with the newly revealed connector.
    • The two screws that are outlined in yellow are not relevant to this step and are marked on the board itself. For this step, yellow corresponds to the yellow rectangle in the image.
  20. MacBook Pro 13" Touch Bar 2018 Left fan Replacement, Unplug left Thunderbolt ports: 20 단계, 이미지 2개 중 1개 MacBook Pro 13" Touch Bar 2018 Left fan Replacement, Unplug left Thunderbolt ports: 20 단계, 이미지 2개 중 2개
    • Once the screw have been removed carefully remove the metal shield.
    • Under the metal shield there is a connector, carefully unplug it.
  21. MacBook Pro 13" Touch Bar 2018 Left fan Replacement, Unplug Touch ID and Auxiliary port: 21 단계, 이미지 3개 중 1개 MacBook Pro 13" Touch Bar 2018 Left fan Replacement, Unplug Touch ID and Auxiliary port: 21 단계, 이미지 3개 중 2개 MacBook Pro 13" Touch Bar 2018 Left fan Replacement, Unplug Touch ID and Auxiliary port: 21 단계, 이미지 3개 중 3개
    • Use a T4 Torx driver to remove the two screws.
    • Two T4 Torx screws.
    • Carefully remove the metal shield.
    • Under the metal shield you will find two connectors, carefully unclip them.
    • The second cable you will disconnect will be lightly adhered so carefully slide a plastic spudger under it and finally unplug it.
    • The adhered cable is very thin and delicate so don't rush it and take your time.
  22. MacBook Pro 13" Touch Bar 2018 Left fan Replacement, Disconnecting the display connector: 22 단계, 이미지 3개 중 1개 MacBook Pro 13" Touch Bar 2018 Left fan Replacement, Disconnecting the display connector: 22 단계, 이미지 3개 중 2개 MacBook Pro 13" Touch Bar 2018 Left fan Replacement, Disconnecting the display connector: 22 단계, 이미지 3개 중 3개
    • Use a T3 Torx driver to remove the four screws.
    • 4 T3 Torx screws.
    • Once the screws are removed carefully remove the metal shields.
    • Carefully unclip the connector.
  23. MacBook Pro 13" Touch Bar 2018 Left fan Replacement, Disconnect wifi and Bluetooth antennas: 23 단계, 이미지 1개 중 1개
    • Disconnect the cables carefully with a plastic pry tool.
    • Be gentle, if too much force is applied it can take the board connector up with it.
  24. MacBook Pro 13" Touch Bar 2018 Left fan Replacement, Touch Bar cable 1: 24 단계, 이미지 3개 중 1개 MacBook Pro 13" Touch Bar 2018 Left fan Replacement, Touch Bar cable 1: 24 단계, 이미지 3개 중 2개 MacBook Pro 13" Touch Bar 2018 Left fan Replacement, Touch Bar cable 1: 24 단계, 이미지 3개 중 3개
    • Remove the metal shield carefully.
    • Carefully unplug the connector.
  25. MacBook Pro 13" Touch Bar 2018 Left fan Replacement, Right speaker cable: 25 단계, 이미지 1개 중 1개
  26. MacBook Pro 13" Touch Bar 2018 Left fan Replacement, ZIF connector: 26 단계, 이미지 1개 중 1개
  27. MacBook Pro 13" Touch Bar 2018 Left fan Replacement, Unplug Right Thunderbolt ports: 27 단계, 이미지 2개 중 1개 MacBook Pro 13" Touch Bar 2018 Left fan Replacement, Unplug Right Thunderbolt ports: 27 단계, 이미지 2개 중 2개
  28. MacBook Pro 13" Touch Bar 2018 Left fan Replacement, Touch bar bracket / Flex: 28 단계, 이미지 3개 중 1개 MacBook Pro 13" Touch Bar 2018 Left fan Replacement, Touch bar bracket / Flex: 28 단계, 이미지 3개 중 2개 MacBook Pro 13" Touch Bar 2018 Left fan Replacement, Touch bar bracket / Flex: 28 단계, 이미지 3개 중 3개
    • Use a T4 Torx driver to remove the screw.
    • T4 Torx screw.
  29. MacBook Pro 13" Touch Bar 2018 Left fan Replacement, Audio socket / Touch ID bracket: 29 단계, 이미지 2개 중 1개 MacBook Pro 13" Touch Bar 2018 Left fan Replacement, Audio socket / Touch ID bracket: 29 단계, 이미지 2개 중 2개
    • Use a T3 Torx driver to remove the two 1.4mm screws securing the bracket.
    • Remove the bracket.
  30. MacBook Pro 13" Touch Bar 2018 Left fan Replacement: 30 단계, 이미지 3개 중 1개 MacBook Pro 13" Touch Bar 2018 Left fan Replacement: 30 단계, 이미지 3개 중 2개 MacBook Pro 13" Touch Bar 2018 Left fan Replacement: 30 단계, 이미지 3개 중 3개
    • gently disconnect the audio socket flex cable with a spudger.
    • gently disconnect the Touch ID flex cable with a spudger.
  31. MacBook Pro 13" Touch Bar 2018 Left fan Replacement, Display cable: 31 단계, 이미지 3개 중 1개 MacBook Pro 13" Touch Bar 2018 Left fan Replacement, Display cable: 31 단계, 이미지 3개 중 2개 MacBook Pro 13" Touch Bar 2018 Left fan Replacement, Display cable: 31 단계, 이미지 3개 중 3개
    • Use a T3 Torx driver to remove the two 2.4mm screws securing the display cable bracket.
    • Use a T3 Torx driver to remove the two 1.2mm screws securing the display cable bracket.
    • gently disconnect the flex cable with a spudger.
  32. MacBook Pro 13" Touch Bar 2018 Left fan Replacement: 32 단계, 이미지 1개 중 1개
    • Use a T5 Torx driver to remove the six 2.2mm screws securing the logic board.
    • Use a T3 Torx driver to remove the three 1.9mm screws securing the logic board.
    • Use a T5 Torx driver to remove the two 2.3mm (3.7mm head) screws securing the heatsink.
  33. MacBook Pro 13" Touch Bar 2018 Left fan Replacement: 33 단계, 이미지 1개 중 1개
    • Carefully lift up the logic board, make sure none of the connectors are connected, also make sure they aren't caught on the logic board.
  34. MacBook Pro 13" Touch Bar 2018 Left fan Replacement: 34 단계, 이미지 1개 중 1개
    • Congratulations you have now removed your MacBook's LogicBoard
  35. MacBook Pro 13" Touch Bar 2018 Left fan Replacement, Left fan: 35 단계, 이미지 1개 중 1개
    • Use a T3 Torx driver to remove the four 2.1mm screws securing the left fan board.
  36. MacBook Pro 13" Touch Bar 2018 Left fan Replacement: 36 단계, 이미지 1개 중 1개
  37. MacBook Pro 13" Touch Bar 2018 Left fan Replacement: 37 단계, 이미지 1개 중 1개
    • Remove the left fan.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
David Fear
회원 가입일: 09/08/11
5,226 평판
안내서 6개를 작성함
Pickle IT - Gadget Repair Pickle IT - Gadget Repair 회원
Business
2 회원들
안내서 22개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 24
지난 30일: 116
전체 시간: 1,906
