소개
This Guide will show you how to replace your MacBook Pro's USB-C/Thunderbolt Ports.
필요한 것
Power on your Mac and launch Terminal.
Copy and paste the following command (or type it exactly) into Terminal:
'sudo nvram AutoBoot=%00
Press [return]. If prompted, enter your administrator password and press [return] again. Note: Your return key may also be labeled ⏎ or "enter."
sudo nvram AutoBoot=%03
Use a P5 Pentalobe driver to remove the six screws securing the lower case:
Two 6.2 mm screws
Four 3.4 mm screws
Apply a suction handle to the lower case near the front-center area of the MacBook Pro.
Lift the suction handle to create a slight gap between the lower case and the chassis.
Insert one corner of an opening pick into the space between the lower case and the chassis.
Slide the opening pick around the nearest corner and halfway up the side of the case.
Insert your opening pick once again under the front edge of the lower case, near one of the two centermost screw holes.
Give the pick a firm twist to pop free the third clip securing the lower case to the chassis.
Repeat this procedure near the other of the two centermost screw holes, popping the fourth clip free.
Carefully peel up the large piece of tape covering the battery connector, on the edge of the logic board nearest the battery.
Remove the tape.
Use a spudger to gently lift the battery power connector, disconnecting the battery.
Lift the connector high enough so that it stays separated from its socket. If it accidentally makes contact during the course of your repair, it could damage your MacBook Pro.
Use a T3 Torx driver to remove the two 1.8 mm screws securing the trackpad cable connector bracket.
Use a T3 Torx driver to remove the two screws.
Two T3 Torx Screws.
Carefully peel back the black tape to reveal the ZIF connector.
Unlatch the ZIF connector by flicking the arm on the connector upwards and carefully remove the cable from the connector by sliding it out.
Repeat this process with the newly revealed connector.
Once the screw have been removed carefully remove the metal shield.
Under the metal shield there is a connector, carefully unplug it.
Use a T4 Torx driver to remove the two screws.
Two T4 Torx screws.
Carefully remove the metal shield.
The second cable you will disconnect will be lightly adhered so carefully slide a plastic spudger under it and finally unplug it.
Use a T3 Torx driver to remove the four screws.
4 T3 Torx screws.
Once the screws are removed carefully remove the metal shields.
Carefully unclip the connector.
Disconnect the cables carefully with a plastic pry tool.
Remove the metal shield carefully.
Carefully unplug the connector.
Use a T4 Torx driver to remove the screw.
T4 Torx screw.
Use a T3 Torx driver to remove the two 1.4mm screws securing the bracket.
Use a T3 Torx driver to remove the two 2.4mm screws securing the display cable bracket.
Use a T3 Torx driver to remove the two 1.2mm screws securing the display cable bracket.
Use a T5 Torx driver to remove the two screws.
Two T5 screws
Carefully remove the port
다른 2명이 해당 안내서를 완성하였습니다.
댓글 2개
What's the minimum toolkit needed to complete this job?
This repair has a variety of screws so probably the Mako kit
Mako Driver Kit - 64 Precision Bits
