소개
根据这个指南来替换掉损耗的电池。如果你的电池鼓包了,
필요한 것
동영상 개요
使用电池顶部的塑料拉手拉出电池。
把电池充满,然后至少继续充电两个小时。之后,像往常一样使用它,消耗电量。当你看到低电量警告时,保存好你的工作,然后让笔记本开着,直到它因为低电量而入睡。再等待至少五个小时,之后再把你的笔记本充满到100%
如果在安装新电池后你发现了一些异常状况或麻烦,你可能需要重置你的Macbook的设备管理器
若要重新组装你的设备,按照本指南的相反顺序操作。
把你的电子垃圾交给 R2 或 e-Stewards 认证的回收商。
다른 769명이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
100%
이 번역자 분들은 저희가 세상을 수리하는데 동참해 주시는 분입니다! 기여하시겠습니까?
번역 시작하기 ›
댓글 48개
I thought these batteries couldn't be replaced.
These batteries are built to the same spec as OEM (Apple)
They are just not "user friendly" to replace like most devices are, the price we pay for pretty devices.
This guide is excellent and now I know I need 1 more tool before I do this myself. I need that tri-wing screwdriver.
Clear, well written instructions, thank you! (But yes, a line about take off shoes and socks and ground yourself is helpful. )
