소개
Use this guide to replace a broken AirPort/Bluetooth board.
Remove the following ten screws:
Three 14.4 mm Phillips #00 screws
Three 3.5 mm Phillips #00 screws
Four 3.5 mm shouldered Phillips #00 screws
Use the edge of a spudger to pry the battery connector upwards from its socket on the logic board.
Use the flat end of a spudger to pry the AirPort/Bluetooth ribbon cable connector up from its socket on the logic board.
Peel back the piece of EMI tape covering the AirPort/Bluetooth cable connector.
다른 88명이 해당 안내서를 완성하였습니다.
댓글 4개
If you change your bluetooth card, its MAC address will change. Since pairing is done by MAC, you will need to re-pair all devices.
My Wifi failed, "no hardware found", but the Bluetooth still worked. I replaced the board, but still no dice. Turns out it was the cable. Lesson learned: try the cheaper part first! Not a total loss, now I have Bluetooth 4.
Hello,
I was able to complete this repair in less than 40 minutes, thanks to the author and his easy-to-follow guide!
Regarding Step 10 - I found it easier to use a Phillips #000 screwdriver (instead of the recommended #00 size) for the two “orange” 3.1 mm Phillips screws, as it did not slide off the tiny screw heads like the larger-sized screwdriver would.
This is an amazingly succinct and clear at of instructions! My Hat is of to you!
I discovered that the flat wifi cable was not properly plugged in, so I plugged it back in and went no further! Yea it worked!
