소개
Use this guide to replace a worn-out battery. If your battery is swollen, take appropriate precautions.
동영상 개요
Remove the following ten screws:
Three 14.4 mm Phillips #00 screws
Three 3.5 mm Phillips #00 screws
Four 3.5 mm shouldered Phillips #00 screws
Use the edge of a spudger to pry the battery connector upwards from its socket on the logic board.
Remove the following two screws:
One 5.6 mm Tri-point screw
One 13 mm Tri-point screw
Use the attached plastic pull tab to remove the battery from the upper case.
Charge it to 100%, and then keep charging it for at least 2 more hours. Next, unplug and use it normally to drain the battery. When you see the low battery warning, save your work, and keep your laptop on until it goes to sleep due to low battery. Wait at least 5 hours, then charge your laptop uninterrupted to 100%.
If you notice any unusual behavior or problems after installing your new battery, you may need to reset your MacBook's SMC.
다른 489명이 해당 안내서를 완성하였습니다.
댓글 12개
Just replaced the battery of MacBook Pro Early 2011. Shipment was blazing fast. I ordered on Saturday and received the battery on Monday morning. It took me just 15 minutes with the right tools to change the battery. iFixit's step by step guide helped me to accomplish the task perfectly in the right way.
I ordered a replacement battery from iFixit to squeeze some more life out of my early 2011 Macbook Pro. The new battery is great, my computer lasts way longer now which is super helpful. The guide helped me easily swap out the battery in less than 20 minutes. :)
I ordered a new battery and the required supplied to replace the batter in my early-2011 13" MacBook Pro. The process was extremely easy and took about 15-20 minutes. I was a little disappointed with the actual battery performance. Before replacing, my battery lasted about 30 minutes. Now it's about 2-2 1/2 hours. I was hoping the new battery replacement I purchased from them would have a longer life than 2 1/2 hours.
