이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
Update an aging MacBook Pro with a new set of feet.
필요한 것
Remove the following ten screws:
Three 14.4 mm Phillips #00 screws
Three 3.5 mm Phillips #00 screws
Four 3.5 mm shouldered Phillips #00 screws
Align the new foot inside the foot pad.
Make sure the alignment nub on the foot is lined up with the small hole near the perimeter of the pad.
Lay the foot down while keeping it properly aligned.
Check for proper alignment from the inside of the lower case. Use tweezers to slide the alignment nub so it lines up with the hole.
다른 31명이 해당 안내서를 완성하였습니다.
