주요 콘텐츠로 건너뛰기
기기를 수리하세요
수리할 권리
상점
소개
Internal prerequisite.
부품
지정된 부품이 없습니다.
  1. Remove the two Phillips screws securing the hard drive bracket to the upper case.
    • Remove the two Phillips screws securing the hard drive bracket to the upper case.
    • These screws will remain attached to the hard drive bracket.
  2. Remove the hard drive bracket.
    • Remove the hard drive bracket.
    • The hard drive bracket may be firmly seated against the upper case.
  3. Use the attached pull tab to lift the hard drive out of the upper case.
    • Use the attached pull tab to lift the hard drive out of the upper case.
    • Don't try to completely remove the hard drive just yet. It is still attached to the hard drive cable.
  4. Pull the hard drive cable away from the body of the hard drive. Remove the hard drive.
    • Pull the hard drive cable away from the body of the hard drive.
    • Remove the hard drive.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Andrew Bookholt
553,078 평판
안내서 618개 작성하였습니다
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 3
전체 시간: 1,267
