이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
Use this guide to replace a blown subwoofer or right speaker.
필요한 것
Remove the following ten screws:
Three 14.4 mm Phillips #00 screws
Three 3.5 mm Phillips #00 screws
Four 3.5 mm shouldered Phillips #00 screws
Use the edge of a spudger to pry the battery connector upwards from its socket on the logic board.
Use the flat end of a spudger to pry the AirPort/Bluetooth ribbon cable connector up from its socket on the logic board.
Use a plastic opening tool or another thin prying object to carefully pry the right speaker up from the adhesive securing it to the upper case.
Pry up along the edge of the right speaker until it is separated from the upper case.
다른 42명이 해당 안내서를 완성하였습니다.
댓글 4개
General - the reason you are reading this guide may well be that you blew you speakers after installing 'Boom' from the App Store.
All I can say is, don't install it a second time!
Others, be warned! If you use Boom, just use it at the lowest volume you can. Looks like they don't replace speakers.
Or better, don't install it at all.
Stuart.
i did it!! what i can say is the details of the step will bring no mistake even for a beginner to change the spare part!
thank IFIXIT!!
Completed! Things to watch out for.
- Make sure you take note of how the cables are organised in their holders and along the chassis. Once you take them out it’s hard to get them to align back to the factory setting.
- The speaker attached to the antenna assembly has a slot that it falls into which puts the whole unit down lower. I had it sitting in a position that seemed right, but a little bit high. I gave it a slight wiggle and it fell into place, which also brings the antenna cables down lower and away from the case cover.
- The glue on the speaker was hard to release. Had to use a hair dryer & heat up the speaker. Def try & find a very thin spudger or this part is complicated. There seems to be less system wires to damage on the end closer to the hard drive. The antenna wire is too close to the other.
- The screws for the optical drive are tiny and can be pretty hard to drop into place once the drive is in position. I used a bit of blu tac on the end of a screwdriver to lower them down before tightening.
