소개
Use this guide to replace a dead hard drive.
동영상 개요
Remove the following ten screws:
Three 14.4 mm Phillips #00 screws
Three 3.5 mm Phillips #00 screws
Four 3.5 mm shouldered Phillips #00 screws
Use the edge of a spudger to pry the battery connector upwards from its socket on the logic board.
Remove the two Phillips screws securing the hard drive bracket to the upper case.
Remove the four 6.0 mm T6 Torx hard drive retaining posts from the sides of the hard drive.
Transfer the hard drive retaining posts to your new hard drive.
다른 245명이 해당 안내서를 완성하였습니다.
댓글 23개
Is there any specific order that's best for putting back the screws?
Start with the corners but after that it dose not matter
Is it possible that my early 2011 macbook pro has T7 screws on the hd instead of the mentioned T6?
I tried removing the screws with a T6 and no luck, the driver seems to be too small. Thanks
Did everything as instructed for a new drive and now constantly getting three beeps. Can't resolve it. Apple says my RAM is wrong but I didn't touch it!
Matt Davis - 답글
