이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
다음 나사 열 개를 풀어주세요:
14.4mm Phillips/십자 #00 나사 세 개
3.5mm Phillips/십자 #00 나사 세 개
3.5mm shouldered Phillips/어깨 십자 #00 나사 네 개
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Use the edge of a spudger to gently pry the fan connector up and out of its socket on the logic board.
Remove the following three screws securing the fan to the logic board:
One 7.2 mm T6 Torx screw
Two 5.3 mm T6 Torx screws
Lift the fan out of its recess in the logic board, minding its cable that may get caught.
Use the tip of a spudger to pull the right speaker/subwoofer cable out from under the retaining finger molded into the upper case.
Pull the right speaker/subwoofer cable upward to lift the connector out of its socket on the logic board.
Disconnect the following four cables:
AirPort/Bluetooth cable
Optical drive cable
Hard drive cable
Trackpad cable
Use your fingernail to flip up the retaining flap on the keyboard ribbon cable ZIF socket.
Use the tip of a spudger to pull the keyboard ribbon cable out of its socket.
If present, remove the small strip of black tape covering the keyboard backlight cable socket.
Use the tip of a spudger or your fingernail to flip up the retaining flap on the keyboard backlight ribbon cable ZIF socket.
Pull the keyboard backlight ribbon cable out of its socket.
Use the flat end of a spudger to pry the sleep sensor/battery indicator connector up from its socket on the logic board.
Grab the plastic pull tab secured to the display data cable lock and rotate it toward the DC-In side of the computer.
Pull the display data cable straight out of its socket on the logic board.
Remove the following nine screws:
Five 3.6 mm T6 Torx screws
Two 4.3 mm T6 Torx screws
Two 7.2 mm T6 Torx screws
Five 3.0 mm T6 screws
Two 3.6 mm T6 screws
Two 6.7 mm T6 screws
Remove the following two screws:
One 8.6 mm Phillips screw
One 5.5 mm Phillips screw
Remove the display data cable retainer from the upper case.
Use the tip of a spudger to gently peel the microphone off the adhesive securing it to the upper case.
Minding the many connectors near its edges, lift the logic board from the end nearest the optical drive.
Without flexing the board, maneuver it out of the upper case, minding the flexible connection to the DC-In board that may get caught in the upper case.
Remove the logic board.
De-route the microphone cable from its slot molded into the left speaker enclosure.
Remove the small piece of black tape covering the left speaker connector.
Use the flat end of a spudger to pry the left speaker connector up from its socket on the logic board.
Carefully pry the left speaker off the foam adhesive securing it to the logic board.
Remove the left speaker.
다른 14명이 해당 안내서를 완성하였습니다.
