이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
Use this guide to replace a damaged plastic clutch cover.
필요한 것
Remove the following 10 screws securing the lower case to the MacBook Pro 13" Unibody:
Seven 3 mm Phillips screws.
Three 13.5 mm Phillips screws.
Slightly lift the lower case and push it toward the rear of the computer to free the mounting tabs.
Use the flat end of a spudger to lift the battery connector up out of its socket on the logic board.
Use the flat end of a spudger to pry the subwoofer/right speaker cable connector up off its socket on the logic board.
Disconnect the camera cable by sliding it horizontally out of its socket.
If you see a small plastic retainer stuck to the logic board that prevents the camera cable from sliding out, peel it up carefully from the logic board. Apply a little heat from a hair dryer or heat gun if necessary to help soften the adhesive holding it in place. Do not attempt to forcibly disconnect the cable with the retainer in place.
If you still have trouble, use the point of a spudger to push at each side of the connector and "walk" it slowly from its socket.
Grab the clutch cover as shown and slide it toward the right side of the display.
다른 24명이 해당 안내서를 완성하였습니다.
댓글 3개
For Step 17...if you are going to be touching the hinge screws on the display, you should consider using Loctite on them when you tighten them. I used this guide to tighten mine, but they worked loose again.
Great guide, no issues at all. I skipped Step 4 (removing subwoofer cable) after reading the comments.
Vielen Dank, tolle Anleitung, hat alles super soweit funktioniert, nur die neue Abdeckung macht beim öffnen des MacBooks jetzt leichte Schleifgeräusche…
Aber viel besser als vor der Reparatur.
