소개
Replace the aluminum bottom case in a MacBook Pro 13" Unibody.
필요한 것
Remove the following 10 screws securing the lower case to the MacBook Pro 13" Unibody:
Seven 3 mm Phillips screws.
Three 13.5 mm Phillips screws.
다른 53명이 해당 안내서를 완성하였습니다.
댓글 한 개
2 tornillos se da&aron, los q estan al lado de las lenguetas de montaje -lado de la bateria- pues la bateria se inflo y presiona la carcasa
q haces p resolver ??
