주요 콘텐츠로 건너뛰기
소개
This guide has been updated by iFixit staff! Read the new, official guide here.
  1. Remove the following 10 screws securing the lower case to the MacBook Pro 13" Unibody:
    • Remove the following 10 screws securing the lower case to the MacBook Pro 13" Unibody:
    • Red Seven 3 mm Phillips screws.
    • Orange Three 13.5 mm Phillips screws.
  2. Slightly lift the lower case and push it toward the rear of the computer to free the mounting tabs.
    • Slightly lift the lower case and push it toward the rear of the computer to free the mounting tabs.
  3. Remove the following tri-wing screws securing the battery to the upper case:
    • Remove the following tri-wing screws securing the battery to the upper case:
    • Red One 5.5 mm tri-wing screw
    • Orange One 13.5 mm tri-wing screw.
  4. PC 노트북 배터리
    큰 전력 향상을 위한 손쉬운 수리.
    지금 장보기
    PC 노트북 배터리
    큰 전력 향상을 위한 손쉬운 수리.
    지금 장보기
  5. Use the flat end of a spudger to lift the battery connector up out of its socket on the logic board.
    • Use the flat end of a spudger to lift the battery connector up out of its socket on the logic board.
  6. Lift the battery out of the upper case
    • Lift the battery out of the upper case
  7. Remove the ribbon cable by releasing it from the ZIF connector on the underside of the trackpad and also from the socket that attaches it to the logic board. Remove the ribbon cable by releasing it from the ZIF connector on the underside of the trackpad and also from the socket that attaches it to the logic board.
    • Remove the ribbon cable by releasing it from the ZIF connector on the underside of the trackpad and also from the socket that attaches it to the logic board.
  8. Remove the four 1.2mm #00 Phillips head screws from rear of the trackpad. Remove the four 1.2mm #00 Phillips head screws from rear of the trackpad.
    • Remove the four 1.2mm #00 Phillips head screws from rear of the trackpad.
결론
다른 8명이 해당 안내서를 완성하였습니다.
SIMRAN
회원 가입일: 2010년 10월 30일
6,309 평판
안내서 1개 작성함
Master Techs Master Techs 회원
Community
287 회원들
안내서 819개 작성하였습니다
I had better luck using the #000 Phillips to get the 1.2mm screws out during step 7.
benchampa - 답글
I accidentally disabled my track pad in the system preferences how do I enable it again when the trackpad wont click?
Nicholas Noriega - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 2
전체 시간: 19,656
