주요 콘텐츠로 건너뛰기
MacBook Pro 13" Unibody Mid 2009 Trackpad Replacement
보관된 가이드
해당 안내서는 단지 역사적인 목적으로 보관됩니다. 최신 버전 안내서를 사용하여 수리 하십시오.
필요한 것
  1. MacBook Pro 13" Unibody Mid 2009 Trackpad Replacement, Trackpad: 1 단계, 이미지 1/1
    • Remove the following 10 screws securing the lower case to the MacBook Pro 13" Unibody:
    • Red Seven 3 mm Phillips screws.
    • Orange Three 13.5 mm Phillips screws.
  2. MacBook Pro 13" Unibody Mid 2009 Trackpad Replacement: 2 단계, 이미지 1/1
    • Slightly lift the lower case and push it toward the rear of the computer to free the mounting tabs.
  3. MacBook Pro 13" Unibody Mid 2009 Trackpad Replacement: 3 단계, 이미지 1/1
    • Remove the following tri-wing screws securing the battery to the upper case:
    • Red One 5.5 mm tri-wing screw
    • Orange One 13.5 mm tri-wing screw.
  4. MacBook Pro 13" Unibody Mid 2009 Trackpad Replacement: 4 단계, 이미지 1/1
    • Use the flat end of a spudger to lift the battery connector up out of its socket on the logic board.
  5. MacBook Pro 13" Unibody Mid 2009 Trackpad Replacement: 5 단계, 이미지 1/1
    • Lift the battery out of the upper case
  6. MacBook Pro 13" Unibody Mid 2009 Trackpad Replacement: 6 단계, 이미지 1/2 MacBook Pro 13" Unibody Mid 2009 Trackpad Replacement: 6 단계, 이미지 2/2
    • Remove the ribbon cable by releasing it from the ZIF connector on the underside of the trackpad and also from the socket that attaches it to the logic board.
  7. MacBook Pro 13" Unibody Mid 2009 Trackpad Replacement: 7 단계, 이미지 1/2 MacBook Pro 13" Unibody Mid 2009 Trackpad Replacement: 7 단계, 이미지 2/2
    • Remove the four 1.2mm #00 Phillips head screws from rear of the trackpad.
결론
다른 8명이 해당 안내서를 완성하였습니다.
SIMRAN
회원 가입일: 10/30/10
6,363 평판
안내서 1개 작성함
Master Techs Master Techs 회원
Community
322 회원들
안내서 2,521개 작성하였습니다
댓글 2개
I had better luck using the #000 Phillips to get the 1.2mm screws out during step 7.
benchampa - 답글
I accidentally disabled my track pad in the system preferences how do I enable it again when the trackpad wont click?
Nicholas Noriega - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 2
전체 시간: 19,726
