이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
하단 케이스를 MacBook Pro 13" Unibody에 고정하는 다음 나사 열 개를 풀어주세요:
3mm 십자 나사 일곱 개
13.5mm 십자 나사 세 개.
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Use the flat end of a spudger to lift the battery connector up out of its socket on the logic board.
Use the flat end of a spudger to pry up the subwoofer/right speaker cable connector out of its socket on the logic board.
Disconnect the camera cable by pulling the male end straight away from its socket.
Remove the following screws:
Two 10 mm Phillips screws
One 3.8 mm Phillips screw
Slide the camera cable bracket out from under the subwoofer and remove it from the computer.
Grab the plastic pull tab secured to the display data cable lock and rotate it toward the DC-In side of the computer.
Pull the display data cable connector straight away from its socket.
Make sure to pull the connector straight away and not straight up from its socket.
Remove the following two screws securing the display data cable bracket to the upper case:
One 8.6 mm Phillips screw
One 5.6 mm Phillips screw
Lift the display data cable bracket out of the upper case.
Remove the two outer 6.5 mm T8 Torx screws securing each of the two display brackets to the upper case (4 screws total).
Open your MacBook so the display is perpendicular to the upper case.
Place your opened MacBook on a table as pictured.
While holding the display and upper case together with your left hand, remove the remaining 6.5 mm T8 Torx screw from the lower display bracket.
Remove the last remaining T8 Torx screw securing the display to the upper case.
Grab the upper case with your right hand and rotate it slightly toward the top of the display so the upper display bracket clears the edge of the upper case.
Rotate the display slightly away from the upper case.
Lift the display up and away from the upper case, minding any brackets or cables that may get caught.
With the heat gun set to low, start by heating the outer black border near the upper right corner of the glass panel.
이 단계에 사용된 도구:Heavy-Duty Suction Cups (Pair)$14.95-
With the panel sufficiently heated, fasten a heavy-duty suction cup near the upper right corner of the display glass.
Slowly and gently pull the corner of the display glass up off the display assembly.
Gently lift the corner of the display glass enough to insert a spudger between it and the display assembly.
Use the flat end of a spudger to gently pry up the adhesive securing the front glass to the display.
Pry up the glass panel a few inches away from the upper right corner along the top and right edges of the display.
Use a heat gun to soften the adhesive under the black strip along the right side of the front glass panel.
Attach a suction cup along the right side of the front glass panel.
Pull up on the glass panel while you use the flat end of a spudger to separate it from the rest of the display assembly.
Continue working along the right edge of the front display glass until it is separated from the display.
Use your heat gun to soften the adhesive under the black strip along the top edge of the glass display panel.
Attach a suction cup near the top edge of the glass display panel and use it to pull the glass panel up off the display.
Work along the top edge of the glass panel, carefully using the flat end of a spudger to separate the adhesive if necessary.
Use a heat gun to soften the adhesive under the black strip near the upper left corner of the glass display panel.
Attach a suction cup near the upper left corner of the glass display panel.
Pull up on the suction cup and use the flat end of a spudger to carefully pry the glass display panel out of the display assembly.
Use a heat gun or hair dryer to soften the adhesive under the black strip along the left side of the front glass panel.
Attach a suction cup along the left side of the front glass panel.
Continue working along the left edge of the front display glass until it is separated from the display.
Now that the top, left, and right edges of the glass are free from the display, slowly lift the top edge of the glass panel and gently rotate it out of the display.
Insert the edge of a plastic opening tool between the display glass and the camera bracket, and run it around the camera bracket to separate it from the display glass.
To reconnect the cable, first use the tip of a spudger to remove the piece of foam tape over the camera cable ZIF socket.
Use the tip of a spudger to flip up the ZIF cable retainer on the camera cable socket.
Insert the camera cable into its socket on the camera board and use the tip of a spudger to snap down the ZIF cable retainer, locking the cable in place.
다른 70명이 해당 안내서를 완성하였습니다.
댓글 7개
If the glass you are replacing is badly broken the suction cups may not attach. I ended up having to remove the glass piece by piece and the process took a couple of hours. You should wear protective glasses and wear rubber gloves to prevent getting finger prints on the lcd screen. Although this was a time consuming process I was successful removing the broken glass and replacing without any issues.
I actually had the same problem as David but in 2 hrs I had removed all of the glass pieces. Now my MB looks like it had never fallen!
Thanks ifixit, you saved me €450.
PS. the parts were in Belgium in 3.5 days, I was amazed at how fast it was.
I found it more convenient to lay the computer keyboard-down on a table with the display hanging over the edge while performing steps 11–15.
The need for a hot air gun greatly increases the possibility of damaging various parts of the laptop [keyboard, airport antenna assembly, clutch cover, strip around the screen, even the screen, possibly the two brackets --- which allow the top and bottom cases to fold together for the clamshell effect --- which are not metal but rather plastic painted to look like metal]. Some people have spent the extra money to buy a special hot air gun with a small focused spout. But, the smarter, simpler, approach is to forget about replacing just the front glass cover and replace the entire display assembly instead. iFixIt is currently out of stock of entire display assemblies, but you can find them elsewhere on the Net for $100 or less. Instead of buying iFixIt's glass cover and recommended tools, I could have bought the entire display assembly for about the same money.
