주요 콘텐츠로 건너뛰기
MacBook Pro 13" Unibody Mid 2012 하단 케이스 교체
필요한 것
  1. MacBook Pro 13" Unibody Mid 2012 하단 케이스 교체, 하단 케이스: 1 단계, 이미지 1/1
    • 다음 나사 열 개를 풀어주세요:
    • 14.4mm Phillips/십자 #00 나사 세 개
    • 3.5mm Phillips/십자 #00 나사 세 개
    • 3.5mm shouldered Phillips/어깨 십자 #00 나사 네 개
    • 작은 나사들을 교체할 때 약간 굽은 케이스에 수직으로 맞추세요 (똑바로 내려 가지 않습니다).
    How much weight can I save by removing the optical drive?
    gunes314 - 답글
    You can save a lot of weight if lets say your installing a solid state drive or putting in a second hard drive but if you know that you use the CD/DVD disc drive a lot then you might just want to leave the drive alone.
    Marshall WahlstromHelgren -
    Tip: Use one of those weekday pill holders to have a cheep way to store screws you remove and each day of the week can be for different sizes or parts. It has been handy to have (much less expensive than the magnetic mat.
    Robert Wacker - 답글
    Hello, where can I buy the screws I need in case I lose one of them?
    taylornya - 답글
    I have one stripped screw... How opening without drill it?! Any suggestions please?
    rodrigosady - 답글
    I also stripped a couple screws. I wasn’t able to open it up without drilling. After drilling the heads and removing the cover it was easy to hacksaw the tip and unscrew with a standard driver.
    Michael Wilkens -
    My top tip - make sure you buy good quality Phillips screwdrivers and a magnetic holder. Cheap screwdrivers won’t get the screws undone safely. Without a magnetic holder you have no chance of getting the tiny crews in and out safely.
    jeremyyoung - 답글
    A good Phillips 00 is your friend here. Also, when reinserting the screws, gently start anticlockwise and you wil feel a click at the start of the thread. This tells you you’re in the right place and less likely to cross-thread through force in the wrong place.
    Iain Boyd - 답글
    I feel like these are 000 screws. Amazon sales describe them as such and my 000 screwdriver fits better
    cam2000deluxe -
    Before ordering a new Trackpad remove the existing battery and try clicking the Trackpad. If it clicks OK with the battery out the source of problem is likely a swollen battery, which should to be replaced even if it still works to some degree. From the side of the battery you will likely see the soft part of the battery bulging beyond the hard case.
    Patrick Langvardt - 답글
    That’s absolutely correct as I can testify. With the battery removed I also adjusted the T6 set screw that adjusts the sensitivity of the trackpad click, evidently someone had cranked mine down tighter than the factory setting.
    Gary Register -
    Le quatrième paragraphe dans les instructions en français n’est pas correct : ce ne sont pas les 2 petites vis, mais les 7 petites vis qui sont inclinées. Et les 3 grandes sont bien verticales.
    Degeorges - 답글
    Bonjour ! Merci de votre observation. J’ai corrigé la traduction. iFixit étant un wiki, n’hésitez pas à modifiez si vous remarquez une erreur :) Encore merci de votre attention et à bientôt !
    Claire Miesch -
    Tip: if you have a magnetic screw mat or similar, lay the macbook over the mat to make sure it catches any screws that may decide to fall of and hide under your table
    Moritz - 답글
    Funny, it's not her hands that are doing the close ups. :)
    Cinemated Man - 답글
    What's the difference between the shouldered and non shouldered screws? They look exactly the same to me.
    MLNLRD - 답글
  2. MacBook Pro 13" Unibody Mid 2012 하단 케이스 교체: 2 단계, 이미지 1/2 MacBook Pro 13" Unibody Mid 2012 하단 케이스 교체: 2 단계, 이미지 2/2
    • MacBook 본체 벤트 근처 하단 케이스를 손가락으로 들어올려 분리하세요.
    • 하단 케이스를 분리하세요.
결론
기기를 재조립하려면 이 지침을 역순으로 따르세요.
다른 85명이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
en ko
100%
Christian Kim님은 저희가 세상을 수리하는데 동참하신 분입니다! 기여하시겠습니까?
번역 시작하기 ›
Andrew Optimus Goldheart
회원 가입일: 10/17/09
502,786 평판
안내서 407개 작성하였습니다
iFixit iFixit 회원
Staff
135 회원들
안내서 16,764개 작성하였습니다
댓글 7개
When purchasing a new bottom panel, do any of the stickers or pads have to be transferred to the new part? How?
Matthew Parrott - 답글
This is the instructions on how to just remove the bottom cover to access other components. The part is sold here on iFixit for $99 and looks to include the rubber feet.
Cwoodyard -
Where can I get a new backover?
SkyGamer - 답글
The back cover is sold here and can be found at the top of the page.
Cwoodyard -
Can i buy this bottom replacement piece here or is this instructions on how to do it?
itsRadioBiz - 답글
These are instruction on how to replace the cover as if it came with the screws and rubber feet. There are other tutorials on this site on replacing the rubber feet and they do sell the bottom casing (with the rubber feet) and screws here.
Cwoodyard -
Guys, I respect you really. Your effort and hard work through all this years is trully remarkable. A R.T.R rulz! Shout out! Thanks for all guides, teardowns, for all that funky, cool stuff you’ve been disassembling and putting back together over and over again, and again. It is helpful. But this 99USD? What? For a 13 inch plate that’s been made of aluminium? Hm.. let me think…should i buy two plates of aluminium or a used, working Macbook? Wait a second. Maybe I can buy it for even less than this plates, cause the full price with shipping and fees would cost me somewhere around 270 USD. Great! All the best!
Igor - 답글
댓글 쓰기
조회 통계:
24 시간 전: 6
7일 전: 46
30일 전: 139
전체 시간: 64,886
