주요 콘텐츠로 건너뛰기
MacBook Pro 13" Unibody Mid 2012 Feet Replacement
필요한 것
  1. MacBook Pro 13" Unibody Mid 2012 Feet Replacement, Lower Case: 1 단계, 이미지 1개 중 1개
    • Remove the following ten screws:
    • Three 14.4 mm Phillips #00 screws
    • Three 3.5 mm Phillips #00 screws
    • Four 3.5 mm shouldered Phillips #00 screws
    • When replacing the small screws, align them perpendicular to the slight curvature of the case (they don't go straight down).
  2. MacBook Pro 13" Unibody Mid 2012 Feet Replacement: 2 단계, 이미지 2개 중 1개 MacBook Pro 13" Unibody Mid 2012 Feet Replacement: 2 단계, 이미지 2개 중 2개
    • Use your fingers to pry the lower case away from the body of the MacBook near the vent.
    • Remove the lower case.
  3. MacBook Pro 13" Unibody Mid 2012 Feet Replacement, Feet: 3 단계, 이미지 3개 중 1개 MacBook Pro 13" Unibody Mid 2012 Feet Replacement, Feet: 3 단계, 이미지 3개 중 2개 MacBook Pro 13" Unibody Mid 2012 Feet Replacement, Feet: 3 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Remove any broken or damaged feet.
    • Remove any pieces from the old foot that may have broken off in the foot hole.
    • Use tweezers to peel up and remove the old adhesive tape from the foot pad.
  4. MacBook Pro 13" Unibody Mid 2012 Feet Replacement: 4 단계, 이미지 1개 중 1개
    • Scrub the foot pad with adhesive remover to remove any remaining adhesive.
  5. MacBook Pro 13" Unibody Mid 2012 Feet Replacement: 5 단계, 이미지 1개 중 1개
    • Wipe the foot pad with an alcohol prep pad to remove any residue left by the cleaner.
  6. MacBook Pro 13" Unibody Mid 2012 Feet Replacement: 6 단계, 이미지 1개 중 1개
    • Peel a replacement foot from the plastic backing.
  7. MacBook Pro 13" Unibody Mid 2012 Feet Replacement: 7 단계, 이미지 3개 중 1개 MacBook Pro 13" Unibody Mid 2012 Feet Replacement: 7 단계, 이미지 3개 중 2개 MacBook Pro 13" Unibody Mid 2012 Feet Replacement: 7 단계, 이미지 3개 중 3개
    • Align the new foot inside the foot pad.
    • Make sure the alignment nub on the foot is lined up with the small hole near the perimeter of the pad.
    • Lay the foot down while keeping it properly aligned.
    • Check for proper alignment from the inside of the lower case. Use tweezers to slide the alignment nub so it lines up with the hole.
  8. MacBook Pro 13" Unibody Mid 2012 Feet Replacement: 8 단계, 이미지 1개 중 1개
    • Press the new foot down firmly with your finger and maintain pressure for 30 seconds to set the pressure sensitive adhesive. Support the other side of the cover while you press the foot down.
    • Repeat the last six steps for any broken or damaged feet.
결론
다른 48명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Adam O'Camb
회원 가입일: 04/11/15
217,636 평판
안내서 416개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 25
지난 30일: 76
전체 시간: 20,532
