주요 콘텐츠로 건너뛰기
MacBook Pro 13" Unibody Mid 2012 RAM Replacement
필요한 것
  1. MacBook Pro 13" Unibody Mid 2012 RAM Replacement, Lower Case: 1 단계, 이미지 1/1
    • Remove the following ten screws:
    • Three 14.4 mm Phillips #00 screws
    • Three 3.5 mm Phillips #00 screws
    • Four 3.5 mm shouldered Phillips #00 screws
    • When replacing the small screws, align them perpendicular to the slight curvature of the case (they don't go straight down).
  2. MacBook Pro 13" Unibody Mid 2012 RAM Replacement: 2 단계, 이미지 1/2 MacBook Pro 13" Unibody Mid 2012 RAM Replacement: 2 단계, 이미지 2/2
    • Use your fingers to pry the lower case away from the body of the MacBook near the vent.
    • Remove the lower case.
  3. MacBook Pro 13" Unibody Mid 2012 RAM Replacement, Battery Connection: 3 단계, 이미지 1/2 MacBook Pro 13" Unibody Mid 2012 RAM Replacement, Battery Connection: 3 단계, 이미지 2/2
    • Use the edge of a spudger to pry the battery connector upwards from its socket on the logic board.
    • It is useful to pry upward on both short sides of the connector to "walk" it out of its socket. Be careful with the corners of the connectors, they can be easily broken off.
  4. MacBook Pro 13" Unibody Mid 2012 RAM Replacement: 4 단계, 이미지 1/1
    • Bend the battery cable slightly away from its socket on the logic board so it does not accidentally connect itself while you work.
  5. MacBook Pro 13" Unibody Mid 2012 RAM Replacement, RAM: 5 단계, 이미지 1/2 MacBook Pro 13" Unibody Mid 2012 RAM Replacement, RAM: 5 단계, 이미지 2/2
    • Pull the two RAM retaining arms away from the center of the RAM chip.
    • The RAM chip should "pop" up slightly from its socket.
  6. MacBook Pro 13" Unibody Mid 2012 RAM Replacement: 6 단계, 이미지 1/1
    • Pull the RAM stick out of its socket.
    • Repeat this process to remove the second RAM chip.
결론
다른 589명이 해당 안내서를 완성하였습니다.
Andrew Optimus Goldheart
회원 가입일: 10/17/09
502,109 평판
안내서 407개 작성하였습니다
iFixit iFixit 회원
Staff
135 회원들
안내서 16,476개 작성하였습니다
댓글 43개
My mid-2012 2.5 i5 works perfectly with 16 Gb of 1600Mhz DDR3.
nix - 답글
Just replaced my 4GB with 16GB of PNY from Best Buy. AWESOME difference in performance!!
Michael Chandler -
Could you please specify the memory chip that you bought? I need more details in order to get the right one, thanks!
Lin -
Any memory kit that is either validated by Apple or that has the proper channel configuration (9-9-9-24) is okay to use. If you are looking for pure performance RAM, a kit of Corsair Vengeance RAM is okay to use (again, check the channel configuration), but most people will benefit from a kit of Corsair Mac Memory or the kit that iFixit provides in the volume of your choice.
Seji the veggie -
댓글 쓰기
조회 통계:
24 시간 전: 37
7일 전: 186
30일 전: 928
전체 시간: 413,420
