소개
Use this guide to replace a blown subwoofer or right speaker.
필요한 것
Remove the following ten screws:
Three 14.4 mm Phillips #00 screws
Three 3.5 mm Phillips #00 screws
Four 3.5 mm shouldered Phillips #00 screws
Use the edge of a spudger to pry the battery connector upwards from its socket on the logic board.
Use the flat end of a spudger to pry the AirPort/Bluetooth ribbon cable connector up from its socket on the logic board.
Use a plastic opening tool or another thin prying object to carefully pry the right speaker up from the adhesive securing it to the upper case.
Pry up along the edge of the right speaker until it is separated from the upper case.
다른 57명이 해당 안내서를 완성하였습니다.
댓글 5개
Our parts are tested by our parts testing department and come with a warranty. If anything you buy from us does not work, customer service will make it right.
MacBook Pro 13" Unibody (Early 2011-Mid 2012) Subwoofer and Right Speaker
Is there no left speaker? I can only find purchase for right speaker. Sorry I'm a newbie lol. Thank you!
Yep! It is there, but under the logical board. Has another guide here only about left speaker’s replacement to this MacBook model. MacBook Pro 13" Unibody Mid 2012 Left Speaker Replacement
Hello I succeeded to replace the right speaker but now my optical driver don't recognize the CD and I can't put them out.. the button does not work anymore, the only way is th restart the mac and press the mouse and the eject button...
there is an unusual noise at the opening from the optical driver, do you think I put the 3 screws of the optical driver in a wrong way ? I looked at it already and I don't find the solution..
