주요 콘텐츠로 건너뛰기
MacBook Pro 14" Early 2023 Logic Board Replacement
필요한 것
  1. MacBook Pro 14" Early 2023 Logic Board Replacement, Unfasten the lower case: 1 단계, 이미지 2개 중 1개 MacBook Pro 14" Early 2023 Logic Board Replacement, Unfasten the lower case: 1 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    FixMat
    $31.41
    • Completely power off and unplug your MacBook Pro before you start. Close the screen and flip the entire laptop upside-down.
    • Use a P5 Pentalobe driver to remove eight screws securing the lower case:
    • Four 9.3 mm screws
    • Four 5 mm screws
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your device.
  2. MacBook Pro 14" Early 2023 Logic Board Replacement, Unclip the lower case: 2 단계, 이미지 2개 중 1개 MacBook Pro 14" Early 2023 Logic Board Replacement, Unclip the lower case: 2 단계, 이미지 2개 중 2개
    • Press a suction handle into place near the front edge of the lower case, between the screw holes.
    • Pull up on the suction handle to create a small gap under the lower case.
  3. MacBook Pro 14" Early 2023 Logic Board Replacement, Release the right clips: 3 단계, 이미지 3개 중 1개 MacBook Pro 14" Early 2023 Logic Board Replacement, Release the right clips: 3 단계, 이미지 3개 중 2개 MacBook Pro 14" Early 2023 Logic Board Replacement, Release the right clips: 3 단계, 이미지 3개 중 3개
    • Insert an opening pick into the gap you just created.
    • Slide the opening pick around the nearest corner and then halfway up the side of the MacBook Pro.
    • This releases the first of the hidden clips securing the lower case. You should feel and hear the clip pop free.
  4. MacBook Pro 14" Early 2023 Logic Board Replacement, Release the left clips: 4 단계, 이미지 3개 중 1개 MacBook Pro 14" Early 2023 Logic Board Replacement, Release the left clips: 4 단계, 이미지 3개 중 2개 MacBook Pro 14" Early 2023 Logic Board Replacement, Release the left clips: 4 단계, 이미지 3개 중 3개
    • Repeat the previous step on the other side, using an opening pick to to release the second clip.
  5. MacBook Pro 14" Early 2023 Logic Board Replacement, Release the sliding clips: 5 단계, 이미지 3개 중 1개 MacBook Pro 14" Early 2023 Logic Board Replacement, Release the sliding clips: 5 단계, 이미지 3개 중 2개 MacBook Pro 14" Early 2023 Logic Board Replacement, Release the sliding clips: 5 단계, 이미지 3개 중 3개
    • Sliding clips along the back edge of the MacBook further secure the lower case. Separating these clips may require a lot of force—consider using gloves to protect your hands from the sharp edges of the lower case.
    • Firmly pull the lower case away from the back edge, one corner at a time, to disengage the sliding clips.
    • Keep the lower case flat to the MacBook. Don't pull upward until it's completely separated.
  6. MacBook Pro 14" Early 2023 Logic Board Replacement, Remove the lower case: 6 단계, 이미지 3개 중 1개 MacBook Pro 14" Early 2023 Logic Board Replacement, Remove the lower case: 6 단계, 이미지 3개 중 2개 MacBook Pro 14" Early 2023 Logic Board Replacement, Remove the lower case: 6 단계, 이미지 3개 중 3개
    • Remove the lower case.
    • To reinstall the lower case:
    • Lay it down and align the sliding clips with the back edge of the MacBook. Press down on the lower case and slide it toward the back edge to engage the clips.
    • When one side is engaged, it may push the other out of alignment. Check both sides as you push.
    • Once the back corners of the lower case are secured and flush with the frame, press down along the middle of the lower case to engage the four remaining clips.
    • You'll hear and feel each clip snap into place.
  7. MacBook Pro 14" Early 2023 Logic Board Replacement, Disconnect the battery board: 7 단계, 이미지 3개 중 1개 MacBook Pro 14" Early 2023 Logic Board Replacement, Disconnect the battery board: 7 단계, 이미지 3개 중 2개 MacBook Pro 14" Early 2023 Logic Board Replacement, Disconnect the battery board: 7 단계, 이미지 3개 중 3개
    • Peel back any tape covering the battery board data cable connector on the logic board.
  8. MacBook Pro 14" Early 2023 Logic Board Replacement: 8 단계, 이미지 2개 중 1개 MacBook Pro 14" Early 2023 Logic Board Replacement: 8 단계, 이미지 2개 중 2개
    • Use a spudger to gently pry up the locking flap on the ZIF connector for the battery board data cable.
  9. MacBook Pro 14" Early 2023 Logic Board Replacement: 9 단계, 이미지 2개 중 1개 MacBook Pro 14" Early 2023 Logic Board Replacement: 9 단계, 이미지 2개 중 2개
    • Disconnect the battery board data cable by sliding it out from its socket on the logic board.
  10. MacBook Pro 14" Early 2023 Logic Board Replacement, Unfasten the trackpad cable bracket: 10 단계, 이미지 1개 중 1개
    • Use a 3IP Torx Plus driver to remove the two 2.1 mm‑long screws securing the trackpad cable bracket to the logic board.
  11. MacBook Pro 14" Early 2023 Logic Board Replacement, Remove the trackpad cable bracket: 11 단계, 이미지 2개 중 1개 MacBook Pro 14" Early 2023 Logic Board Replacement, Remove the trackpad cable bracket: 11 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Use tweezers, or your fingers, to remove the trackpad cable bracket.
  12. MacBook Pro 14" Early 2023 Logic Board Replacement, Disconnect the trackpad cable: 12 단계, 이미지 2개 중 1개 MacBook Pro 14" Early 2023 Logic Board Replacement, Disconnect the trackpad cable: 12 단계, 이미지 2개 중 2개
    • Use the flat end of a spudger to pry up and disconnect the trackpad cable's press connector secured to the logic board.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Don't press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  13. MacBook Pro 14" Early 2023 Logic Board Replacement, Reposition the trackpad cable: 13 단계, 이미지 2개 중 1개 MacBook Pro 14" Early 2023 Logic Board Replacement, Reposition the trackpad cable: 13 단계, 이미지 2개 중 2개
    • The trackpad cable is lightly adhered to the frame.
    • Peel the trackpad cable away from the device, making sure to separate the adhesive.
  14. MacBook Pro 14" Early 2023 Logic Board Replacement, Disconnect the battery board: 14 단계, 이미지 2개 중 1개 MacBook Pro 14" Early 2023 Logic Board Replacement, Disconnect the battery board: 14 단계, 이미지 2개 중 2개
    • Peel back any tape covering the battery board data cable connector under the large pancake screw.
  15. MacBook Pro 14" Early 2023 Logic Board Replacement: 15 단계, 이미지 2개 중 1개 MacBook Pro 14" Early 2023 Logic Board Replacement: 15 단계, 이미지 2개 중 2개
  16. MacBook Pro 14" Early 2023 Logic Board Replacement: 16 단계, 이미지 2개 중 1개 MacBook Pro 14" Early 2023 Logic Board Replacement: 16 단계, 이미지 2개 중 2개
    • Disconnect the battery board data cable by sliding it out from its socket on the battery board.
  17. MacBook Pro 14" Early 2023 Logic Board Replacement, Remove the data cable: 17 단계, 이미지 2개 중 1개 MacBook Pro 14" Early 2023 Logic Board Replacement, Remove the data cable: 17 단계, 이미지 2개 중 2개
    • The battery board data cable is lightly adhered to the device.
    • Slide blunt nose tweezers under areas with adhesive to separate the cable from the device.
    • Remove the battery board data cable.
  18. MacBook Pro 14" Early 2023 Logic Board Replacement, Unfasten the battery connector: 18 단계, 이미지 1개 중 1개
    • Use a T5 Torx driver to remove the 3.8 mm wide-head screw securing the battery power connector.
  19. MacBook Pro 14" Early 2023 Logic Board Replacement, Disconnect the battery connector: 19 단계, 이미지 3개 중 1개 MacBook Pro 14" Early 2023 Logic Board Replacement, Disconnect the battery connector: 19 단계, 이미지 3개 중 2개 MacBook Pro 14" Early 2023 Logic Board Replacement, Disconnect the battery connector: 19 단계, 이미지 3개 중 3개
    • Use the flat end of your spudger to lift the battery connector away from the battery board, disconnecting the battery.
    • Lift the connector high enough that it doesn't accidentally make contact during the repair, but no more than 45 degrees to prevent damaging its hinge.
    • For added safety, place a barrier, such as a piece of a playing card, between the connector and board.
  20. MacBook Pro 14" Early 2023 Logic Board Replacement, Unfasten the antenna bar's connector bracket: 20 단계, 이미지 2개 중 1개 MacBook Pro 14" Early 2023 Logic Board Replacement, Unfasten the antenna bar's connector bracket: 20 단계, 이미지 2개 중 2개
    • Use a 3IP Torx Plus screwdriver to remove the three 2.1 mm screws securing the antenna board bracket and coaxial cable cover to the frame.
  21. MacBook Pro 14" Early 2023 Logic Board Replacement: 21 단계, 이미지 2개 중 1개 MacBook Pro 14" Early 2023 Logic Board Replacement: 21 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Use tweezers, or your fingers, to remove the cover on top of the antenna bar's coaxial cables.
  22. MacBook Pro 14" Early 2023 Logic Board Replacement, Disconnect the antenna bar: 22 단계, 이미지 2개 중 1개 MacBook Pro 14" Early 2023 Logic Board Replacement, Disconnect the antenna bar: 22 단계, 이미지 2개 중 2개
    • Use the tip of a spudger to pry up and disconnect the antenna bar's coaxial cable.
    • Repeat for the two other cables.
    • During reassembly, these can be tricky to reconnect. Hold each connector in place over its socket and press down with the flat end of a spudger. The connector should snap into place.
  23. MacBook Pro 14" Early 2023 Logic Board Replacement, Unfasten the screen cable covers: 23 단계, 이미지 2개 중 1개 MacBook Pro 14" Early 2023 Logic Board Replacement, Unfasten the screen cable covers: 23 단계, 이미지 2개 중 2개
    • Use a 3IP Torx Plus driver to remove the four 2.1 mm screws securing the screen cable covers.
  24. MacBook Pro 14" Early 2023 Logic Board Replacement, Remove the screen cable covers: 24 단계, 이미지 2개 중 1개 MacBook Pro 14" Early 2023 Logic Board Replacement, Remove the screen cable covers: 24 단계, 이미지 2개 중 2개
    • Use tweezers, or your fingers, to remove the two screen cable covers from the logic board.
  25. MacBook Pro 14" Early 2023 Logic Board Replacement, Disconnect the screen cables: 25 단계, 이미지 3개 중 1개 MacBook Pro 14" Early 2023 Logic Board Replacement, Disconnect the screen cables: 25 단계, 이미지 3개 중 2개 MacBook Pro 14" Early 2023 Logic Board Replacement, Disconnect the screen cables: 25 단계, 이미지 3개 중 3개
    • Use the flat end of a spudger to pry up and disconnect the right-most screen cable press connectors secured to the logic board.
  26. MacBook Pro 14" Early 2023 Logic Board Replacement: 26 단계, 이미지 2개 중 1개 MacBook Pro 14" Early 2023 Logic Board Replacement: 26 단계, 이미지 2개 중 2개
    • Repeat the previous disconnection process for the remaining press connector at the top left of the logic board.
    • Don't pry against the surface-mounted components near the press connector.
  27. MacBook Pro 14" Early 2023 Logic Board Replacement: 27 단계, 이미지 3개 중 1개 MacBook Pro 14" Early 2023 Logic Board Replacement: 27 단계, 이미지 3개 중 2개 MacBook Pro 14" Early 2023 Logic Board Replacement: 27 단계, 이미지 3개 중 3개
    • Peel back any tape covering the microphone cable connector.
  28. MacBook Pro 14" Early 2023 Logic Board Replacement: 28 단계, 이미지 2개 중 1개 MacBook Pro 14" Early 2023 Logic Board Replacement: 28 단계, 이미지 2개 중 2개
    • Use a spudger to gently pry up the locking flap on the ZIF connector for the microphone cable.
  29. MacBook Pro 14" Early 2023 Logic Board Replacement: 29 단계, 이미지 2개 중 1개 MacBook Pro 14" Early 2023 Logic Board Replacement: 29 단계, 이미지 2개 중 2개
    • Disconnect the microphone cable by sliding it out from its socket on the logic board.
  30. MacBook Pro 14" Early 2023 Logic Board Replacement, Unfasten the right-side cable covers: 30 단계, 이미지 2개 중 1개 MacBook Pro 14" Early 2023 Logic Board Replacement, Unfasten the right-side cable covers: 30 단계, 이미지 2개 중 2개
    • Use a 3IP Torx Plus driver to remove the nine 2.1 mm screws securing the right cable covers to the frame:
  31. MacBook Pro 14" Early 2023 Logic Board Replacement, Remove the right cable covers: 31 단계, 이미지 2개 중 1개 MacBook Pro 14" Early 2023 Logic Board Replacement, Remove the right cable covers: 31 단계, 이미지 2개 중 2개
    • Use tweezers, or your fingers, to remove the five right cable covers.
  32. MacBook Pro 14" Early 2023 Logic Board Replacement: 32 단계, 이미지 2개 중 1개 MacBook Pro 14" Early 2023 Logic Board Replacement: 32 단계, 이미지 2개 중 2개
    • Peel back any tape covering the right speaker cable.
  33. MacBook Pro 14" Early 2023 Logic Board Replacement: 33 단계, 이미지 2개 중 1개 MacBook Pro 14" Early 2023 Logic Board Replacement: 33 단계, 이미지 2개 중 2개
    • Use a spudger to gently pry up the locking flap on the ZIF connector for the right speaker cable.
  34. MacBook Pro 14" Early 2023 Logic Board Replacement: 34 단계, 이미지 2개 중 1개 MacBook Pro 14" Early 2023 Logic Board Replacement: 34 단계, 이미지 2개 중 2개
    • Disconnect the right speaker cable by sliding it out from its socket on the logic board.
  35. MacBook Pro 14" Early 2023 Logic Board Replacement, Disconnect the headphone jack: 35 단계, 이미지 2개 중 1개 MacBook Pro 14" Early 2023 Logic Board Replacement, Disconnect the headphone jack: 35 단계, 이미지 2개 중 2개
    • Use a spudger to pry up and disconnect the headphone jack's press connector.
  36. MacBook Pro 14" Early 2023 Logic Board Replacement, Disconnect the right USB-C ports: 36 단계, 이미지 3개 중 1개 MacBook Pro 14" Early 2023 Logic Board Replacement, Disconnect the right USB-C ports: 36 단계, 이미지 3개 중 2개 MacBook Pro 14" Early 2023 Logic Board Replacement, Disconnect the right USB-C ports: 36 단계, 이미지 3개 중 3개
    • Use a spudger to pry up and disconnect the right USB-C ports' press connectors.
  37. MacBook Pro 14" Early 2023 Logic Board Replacement, Disconnect the MagSafe port: 37 단계, 이미지 2개 중 1개 MacBook Pro 14" Early 2023 Logic Board Replacement, Disconnect the MagSafe port: 37 단계, 이미지 2개 중 2개
    • Use a spudger to pry up and disconnect the MagSafe port's press connector.
  38. MacBook Pro 14" Early 2023 Logic Board Replacement, Disconnect the lid angle sensor cable: 38 단계, 이미지 2개 중 1개 MacBook Pro 14" Early 2023 Logic Board Replacement, Disconnect the lid angle sensor cable: 38 단계, 이미지 2개 중 2개
    • Use a spudger to pry up and disconnect the lid angle sensor's press connector.
  39. MacBook Pro 14" Early 2023 Logic Board Replacement, Unfasten the left cable covers: 39 단계, 이미지 2개 중 1개 MacBook Pro 14" Early 2023 Logic Board Replacement, Unfasten the left cable covers: 39 단계, 이미지 2개 중 2개
    • Use a 3IP Torx Plus driver to remove the four screws securing the left cable covers to the frame:
    • Two 2 mm screws
    • Two 2.1 mm screw
  40. MacBook Pro 14" Early 2023 Logic Board Replacement, Remove the left cable covers: 40 단계, 이미지 2개 중 1개 MacBook Pro 14" Early 2023 Logic Board Replacement, Remove the left cable covers: 40 단계, 이미지 2개 중 2개
    • Use tweezers, or your fingers, to remove the two left cable covers.
  41. MacBook Pro 14" Early 2023 Logic Board Replacement, Disconnect the left speaker: 41 단계, 이미지 2개 중 1개 MacBook Pro 14" Early 2023 Logic Board Replacement, Disconnect the left speaker: 41 단계, 이미지 2개 중 2개
    • Peel back any tape covering the left speaker cable.
  42. MacBook Pro 14" Early 2023 Logic Board Replacement: 42 단계, 이미지 2개 중 1개 MacBook Pro 14" Early 2023 Logic Board Replacement: 42 단계, 이미지 2개 중 2개
    • Use a spudger to gently pry up the locking flap on the ZIF connector for the left speaker cable.
  43. MacBook Pro 14" Early 2023 Logic Board Replacement: 43 단계, 이미지 2개 중 1개 MacBook Pro 14" Early 2023 Logic Board Replacement: 43 단계, 이미지 2개 중 2개
    • Disconnect the left speaker cable by sliding it out from its socket on the logic board.
  44. MacBook Pro 14" Early 2023 Logic Board Replacement, Disconnect the left USB-C port: 44 단계, 이미지 2개 중 1개 MacBook Pro 14" Early 2023 Logic Board Replacement, Disconnect the left USB-C port: 44 단계, 이미지 2개 중 2개
    • Use a spudger to pry up and disconnect the left USB-C port's press connector.
  45. MacBook Pro 14" Early 2023 Logic Board Replacement, Disconnect the Touch ID sensor: 45 단계, 이미지 2개 중 1개 MacBook Pro 14" Early 2023 Logic Board Replacement, Disconnect the Touch ID sensor: 45 단계, 이미지 2개 중 2개
    • Use a spudger to pry up and disconnect the Touch ID sensor's press connector near the top left of the device.
    • The Touch ID sensor cable is adhered to the frame. If the adhesive doesn't separate when you disconnect the press connector, slide an opening pick under the cable to separate it.
  46. MacBook Pro 14" Early 2023 Logic Board Replacement, Disconnect the keyboard: 46 단계, 이미지 3개 중 1개 MacBook Pro 14" Early 2023 Logic Board Replacement, Disconnect the keyboard: 46 단계, 이미지 3개 중 2개 MacBook Pro 14" Early 2023 Logic Board Replacement, Disconnect the keyboard: 46 단계, 이미지 3개 중 3개
  47. MacBook Pro 14" Early 2023 Logic Board Replacement: 47 단계, 이미지 3개 중 1개 MacBook Pro 14" Early 2023 Logic Board Replacement: 47 단계, 이미지 3개 중 2개 MacBook Pro 14" Early 2023 Logic Board Replacement: 47 단계, 이미지 3개 중 3개
    • Use a spudger to gently pry up the locking flap on the ZIF connectors for the keyboard cables.
  48. MacBook Pro 14" Early 2023 Logic Board Replacement: 48 단계, 이미지 3개 중 1개 MacBook Pro 14" Early 2023 Logic Board Replacement: 48 단계, 이미지 3개 중 2개 MacBook Pro 14" Early 2023 Logic Board Replacement: 48 단계, 이미지 3개 중 3개
    • Disconnect the keyboard and keyboard backlight cables by sliding them out from their sockets on the logic board.
  49. MacBook Pro 14" Early 2023 Logic Board Replacement, Disconnect the fans: 49 단계, 이미지 3개 중 1개 MacBook Pro 14" Early 2023 Logic Board Replacement, Disconnect the fans: 49 단계, 이미지 3개 중 2개 MacBook Pro 14" Early 2023 Logic Board Replacement, Disconnect the fans: 49 단계, 이미지 3개 중 3개
    • Peel back any tape covering the right fan cable connector.
  50. MacBook Pro 14" Early 2023 Logic Board Replacement: 50 단계, 이미지 2개 중 1개 MacBook Pro 14" Early 2023 Logic Board Replacement: 50 단계, 이미지 2개 중 2개
    • Use a spudger to gently pry up the locking flap on the ZIF connector for the right fan cable.
  51. MacBook Pro 14" Early 2023 Logic Board Replacement: 51 단계, 이미지 2개 중 1개 MacBook Pro 14" Early 2023 Logic Board Replacement: 51 단계, 이미지 2개 중 2개
    • Disconnect the right fan cable by sliding it out from its socket on the logic board.
  52. MacBook Pro 14" Early 2023 Logic Board Replacement, Reposition the right fan cable: 52 단계, 이미지 2개 중 1개 MacBook Pro 14" Early 2023 Logic Board Replacement, Reposition the right fan cable: 52 단계, 이미지 2개 중 2개
    • The right fan cable is lightly adhered to the logic board.
    • Pull the fan cable away from the logic board with tweezers to separate the adhesive.
    • The fan cables are incredibly delicate and prone to tearing; use caution when bending them with tools.
  53. MacBook Pro 14" Early 2023 Logic Board Replacement: 53 단계, 이미지 2개 중 1개 MacBook Pro 14" Early 2023 Logic Board Replacement: 53 단계, 이미지 2개 중 2개
    • Repeat the previous disconnection and reposition procedure for the left fan.
  54. MacBook Pro 14" Early 2023 Logic Board Replacement: 54 단계, 이미지 2개 중 1개 MacBook Pro 14" Early 2023 Logic Board Replacement: 54 단계, 이미지 2개 중 2개
    • Remove the four black screw covers from the logic board.
  55. MacBook Pro 14" Early 2023 Logic Board Replacement, Unfasten the logic board: 55 단계, 이미지 3개 중 1개 MacBook Pro 14" Early 2023 Logic Board Replacement, Unfasten the logic board: 55 단계, 이미지 3개 중 2개 MacBook Pro 14" Early 2023 Logic Board Replacement, Unfasten the logic board: 55 단계, 이미지 3개 중 3개
    • Use a T5 Torx driver to remove the 11 screws securing the logic board:
    • Four 3.6 mm screws
    • Two 4.5 mm screws
    • Two 5.2 mm screws
    • Two 3.8 mm screws
    • One 3.9 mm screw
  56. MacBook Pro 14" Early 2023 Logic Board Replacement: 56 단계, 이미지 3개 중 1개 MacBook Pro 14" Early 2023 Logic Board Replacement: 56 단계, 이미지 3개 중 2개 MacBook Pro 14" Early 2023 Logic Board Replacement: 56 단계, 이미지 3개 중 3개
    • Use a T6 Torx driver to remove the three screws securing the logic board:
    • Two 4.7 mm screws
    • One 5.7 mm screw
  57. MacBook Pro 14" Early 2023 Logic Board Replacement, Release the logic board's clips: 57 단계, 이미지 2개 중 1개 MacBook Pro 14" Early 2023 Logic Board Replacement, Release the logic board's clips: 57 단계, 이미지 2개 중 2개
    • Insert a spudger between the right side of the logic board and the frame.
    • Pry up with the spudger to release the logic board from its clips.
  58. MacBook Pro 14" Early 2023 Logic Board Replacement: 58 단계, 이미지 2개 중 1개 MacBook Pro 14" Early 2023 Logic Board Replacement: 58 단계, 이미지 2개 중 2개
    • Insert a spudger between the bottom of the logic board and the frame.
  59. MacBook Pro 14" Early 2023 Logic Board Replacement, Remove the logic board: 59 단계, 이미지 3개 중 1개 MacBook Pro 14" Early 2023 Logic Board Replacement, Remove the logic board: 59 단계, 이미지 3개 중 2개 MacBook Pro 14" Early 2023 Logic Board Replacement, Remove the logic board: 59 단계, 이미지 3개 중 3개
    • Gently lift up the logic board by its right side to release it from its alignment pegs.
    • If it feels like it's not coming out, check that all the cables are disconnected.
    • Pull the logic board away from the left side of the device to separate the HDMI and SDXC ports from their slots in the frame.
    • Remove the logic board.
  60. MacBook Pro 14" Early 2023 Logic Board Replacement, Reassembly information: 60 단계, 이미지 3개 중 1개 MacBook Pro 14" Early 2023 Logic Board Replacement, Reassembly information: 60 단계, 이미지 3개 중 2개 MacBook Pro 14" Early 2023 Logic Board Replacement, Reassembly information: 60 단계, 이미지 3개 중 3개
    • During reassembly, perform the following:
    • Make sure all 18 connectors are above the logic board before securing it back into the frame.
    • If you're having trouble positioning the connectors, use tape to keep them out of the way.
    • Hold the rubber spacers out of the way so the fins can drop into their recesses.
    • When reinstalling the logic board, insert the left side first to reposition the HMDI and SDXC ports.
    • Use your fingers to slightly compress the HDMI port to fit it into its recess. Otherwise, the logic board won't sit correctly.
  61. MacBook Pro 14" Early 2023 Logic Board Replacement, Unfasten the heat sink: 61 단계, 이미지 2개 중 1개 MacBook Pro 14" Early 2023 Logic Board Replacement, Unfasten the heat sink: 61 단계, 이미지 2개 중 2개
    • Turn the logic board upside-down so that the heat sink screws face upwards.
    • Use a T5 Torx driver to remove the four 3.9 mm screws securing the heat sink to the logic board.
    • Gently hold the screws as you remove them, as the tension brackets may eject them.
    • During reassembly, loosely tighten these screws, then align the brackets and heatsink before fully tightening them in an X-pattern.
  62. MacBook Pro 14" Early 2023 Logic Board Replacement, Remove the heat sink brackets: 62 단계, 이미지 2개 중 1개 MacBook Pro 14" Early 2023 Logic Board Replacement, Remove the heat sink brackets: 62 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Use tweezers, or your fingers, to remove the heat sink brackets.
  63. MacBook Pro 14" Early 2023 Logic Board Replacement, Remove the heat sink: 63 단계, 이미지 2개 중 1개 MacBook Pro 14" Early 2023 Logic Board Replacement, Remove the heat sink: 63 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    iFixit Thermal Paste
    $24.95
  64. MacBook Pro 14" Early 2023 Logic Board Replacement, Only the logic board remains: 64 단계, 이미지 1개 중 1개
    • You're now left with the logic board.
결론
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our MacBook Pro 14" 2023 Answers community for help.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Chayton Ritter
회원 가입일: 08/21/20
24,820 평판
안내서 105개를 작성함
Guide Team Guide Team 회원
Staff
10 회원들
안내서 15,763개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 6
지난 7일: 45
지난 30일: 205
전체 시간: 5,839
