주요 콘텐츠로 건너뛰기
MacBook Pro 14" Early 2023 Screen Replacement
필요한 것
  1. MacBook Pro 14" Early 2023 Screen Replacement, Unfasten the lower case: 1 단계, 이미지 2개 중 1개 MacBook Pro 14" Early 2023 Screen Replacement, Unfasten the lower case: 1 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    FixMat
    $31.41
    • Completely power off and unplug your MacBook Pro before you start. Close the screen and flip the entire laptop upside-down.
    • Use a P5 Pentalobe driver to remove eight screws securing the lower case:
    • Four 9.3 mm screws
    • Four 5 mm screws
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your device.
  2. MacBook Pro 14" Early 2023 Screen Replacement, Unclip the lower case: 2 단계, 이미지 2개 중 1개 MacBook Pro 14" Early 2023 Screen Replacement, Unclip the lower case: 2 단계, 이미지 2개 중 2개
    • Press a suction handle into place near the front edge of the lower case, between the screw holes.
    • Pull up on the suction handle to create a small gap under the lower case.
  3. MacBook Pro 14" Early 2023 Screen Replacement, Release the right clips: 3 단계, 이미지 3개 중 1개 MacBook Pro 14" Early 2023 Screen Replacement, Release the right clips: 3 단계, 이미지 3개 중 2개 MacBook Pro 14" Early 2023 Screen Replacement, Release the right clips: 3 단계, 이미지 3개 중 3개
    • Insert an opening pick into the gap you just created.
    • Slide the opening pick around the nearest corner and then halfway up the side of the MacBook Pro.
    • This releases the first of the hidden clips securing the lower case. You should feel and hear the clip pop free.
  4. MacBook Pro 14" Early 2023 Screen Replacement, Release the left clips: 4 단계, 이미지 3개 중 1개 MacBook Pro 14" Early 2023 Screen Replacement, Release the left clips: 4 단계, 이미지 3개 중 2개 MacBook Pro 14" Early 2023 Screen Replacement, Release the left clips: 4 단계, 이미지 3개 중 3개
    • Repeat the previous step on the other side, using an opening pick to to release the second clip.
  5. MacBook Pro 14" Early 2023 Screen Replacement, Release the sliding clips: 5 단계, 이미지 3개 중 1개 MacBook Pro 14" Early 2023 Screen Replacement, Release the sliding clips: 5 단계, 이미지 3개 중 2개 MacBook Pro 14" Early 2023 Screen Replacement, Release the sliding clips: 5 단계, 이미지 3개 중 3개
    • Sliding clips along the back edge of the MacBook further secure the lower case. Separating these clips may require a lot of force—consider using gloves to protect your hands from the sharp edges of the lower case.
    • Firmly pull the lower case away from the back edge, one corner at a time, to disengage the sliding clips.
    • Keep the lower case flat to the MacBook. Don't pull upward until it's completely separated.
  6. MacBook Pro 14" Early 2023 Screen Replacement, Remove the lower case: 6 단계, 이미지 3개 중 1개 MacBook Pro 14" Early 2023 Screen Replacement, Remove the lower case: 6 단계, 이미지 3개 중 2개 MacBook Pro 14" Early 2023 Screen Replacement, Remove the lower case: 6 단계, 이미지 3개 중 3개
    • Remove the lower case.
    • To reinstall the lower case:
    • Lay it down and align the sliding clips with the back edge of the MacBook. Press down on the lower case and slide it toward the back edge to engage the clips.
    • When one side is engaged, it may push the other out of alignment. Check both sides as you push.
    • Once the back corners of the lower case are secured and flush with the frame, press down along the middle of the lower case to engage the four remaining clips.
    • You'll hear and feel each clip snap into place.
  7. MacBook Pro 14" Early 2023 Screen Replacement, Disconnect the battery board: 7 단계, 이미지 3개 중 1개 MacBook Pro 14" Early 2023 Screen Replacement, Disconnect the battery board: 7 단계, 이미지 3개 중 2개 MacBook Pro 14" Early 2023 Screen Replacement, Disconnect the battery board: 7 단계, 이미지 3개 중 3개
    • Peel back any tape covering the battery board data cable connector on the logic board.
  8. MacBook Pro 14" Early 2023 Screen Replacement: 8 단계, 이미지 2개 중 1개 MacBook Pro 14" Early 2023 Screen Replacement: 8 단계, 이미지 2개 중 2개
    • Use a spudger to gently pry up the locking flap on the ZIF connector for the battery board data cable.
  9. MacBook Pro 14" Early 2023 Screen Replacement: 9 단계, 이미지 2개 중 1개 MacBook Pro 14" Early 2023 Screen Replacement: 9 단계, 이미지 2개 중 2개
    • Disconnect the battery board data cable by sliding it out from its socket on the logic board.
  10. MacBook Pro 14" Early 2023 Screen Replacement, Unfasten the trackpad cable bracket: 10 단계, 이미지 1개 중 1개
    • Use a 3IP Torx Plus driver to remove the two 2.1 mm‑long screws securing the trackpad cable bracket to the logic board.
  11. MacBook Pro 14" Early 2023 Screen Replacement, Remove the trackpad cable bracket: 11 단계, 이미지 2개 중 1개 MacBook Pro 14" Early 2023 Screen Replacement, Remove the trackpad cable bracket: 11 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Use tweezers, or your fingers, to remove the trackpad cable bracket.
  12. MacBook Pro 14" Early 2023 Screen Replacement, Disconnect the trackpad cable: 12 단계, 이미지 2개 중 1개 MacBook Pro 14" Early 2023 Screen Replacement, Disconnect the trackpad cable: 12 단계, 이미지 2개 중 2개
    • Use the flat end of a spudger to pry up and disconnect the trackpad cable's press connector secured to the logic board.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Don't press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  13. MacBook Pro 14" Early 2023 Screen Replacement, Reposition the trackpad cable: 13 단계, 이미지 2개 중 1개 MacBook Pro 14" Early 2023 Screen Replacement, Reposition the trackpad cable: 13 단계, 이미지 2개 중 2개
    • The trackpad cable is lightly adhered to the frame.
    • Peel the trackpad cable away from the device, making sure to separate the adhesive.
  14. MacBook Pro 14" Early 2023 Screen Replacement, Disconnect the battery board: 14 단계, 이미지 2개 중 1개 MacBook Pro 14" Early 2023 Screen Replacement, Disconnect the battery board: 14 단계, 이미지 2개 중 2개
    • Peel back any tape covering the battery board data cable connector under the large pancake screw.
  15. MacBook Pro 14" Early 2023 Screen Replacement: 15 단계, 이미지 2개 중 1개 MacBook Pro 14" Early 2023 Screen Replacement: 15 단계, 이미지 2개 중 2개
  16. MacBook Pro 14" Early 2023 Screen Replacement: 16 단계, 이미지 2개 중 1개 MacBook Pro 14" Early 2023 Screen Replacement: 16 단계, 이미지 2개 중 2개
    • Disconnect the battery board data cable by sliding it out from its socket on the battery board.
  17. MacBook Pro 14" Early 2023 Screen Replacement, Remove the data cable: 17 단계, 이미지 2개 중 1개 MacBook Pro 14" Early 2023 Screen Replacement, Remove the data cable: 17 단계, 이미지 2개 중 2개
    • The battery board data cable is lightly adhered to the device.
    • Slide blunt nose tweezers under areas with adhesive to separate the cable from the device.
    • Remove the battery board data cable.
  18. MacBook Pro 14" Early 2023 Screen Replacement, Unfasten the battery connector: 18 단계, 이미지 1개 중 1개
    • Use a T5 Torx driver to remove the 3.8 mm wide-head screw securing the battery power connector.
  19. MacBook Pro 14" Early 2023 Screen Replacement, Disconnect the battery connector: 19 단계, 이미지 3개 중 1개 MacBook Pro 14" Early 2023 Screen Replacement, Disconnect the battery connector: 19 단계, 이미지 3개 중 2개 MacBook Pro 14" Early 2023 Screen Replacement, Disconnect the battery connector: 19 단계, 이미지 3개 중 3개
    • Use the flat end of your spudger to lift the battery connector away from the battery board, disconnecting the battery.
    • Lift the connector high enough that it doesn't accidentally make contact during the repair, but no more than 45 degrees to prevent damaging its hinge.
    • For added safety, place a barrier, such as a piece of a playing card, between the connector and board.
  20. MacBook Pro 14" Early 2023 Screen Replacement, Unfasten the antenna bar's connector bracket: 20 단계, 이미지 2개 중 1개 MacBook Pro 14" Early 2023 Screen Replacement, Unfasten the antenna bar's connector bracket: 20 단계, 이미지 2개 중 2개
    • Use your 3IP Torx driver to remove the three 2.1 mm-long screws securing the antenna connector cover and bracket.
  21. MacBook Pro 14" Early 2023 Screen Replacement: 21 단계, 이미지 2개 중 1개 MacBook Pro 14" Early 2023 Screen Replacement: 21 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Use tweezers, or your fingers, to remove the cover on top of the antenna bar's coaxial cables.
  22. MacBook Pro 14" Early 2023 Screen Replacement, Disconnect the antenna bar: 22 단계, 이미지 2개 중 1개 MacBook Pro 14" Early 2023 Screen Replacement, Disconnect the antenna bar: 22 단계, 이미지 2개 중 2개
    • Use the tip of a spudger to pry up and disconnect the antenna bar's coaxial cable.
    • Repeat for the two other cables.
    • During reassembly, these can be tricky to reconnect. One at a time, hold each connector in place over its socket and press down with the flat end of a spudger. The connector should snap into place.
  23. MacBook Pro 14" Early 2023 Screen Replacement, Unfasten the antenna bar: 23 단계, 이미지 2개 중 1개 MacBook Pro 14" Early 2023 Screen Replacement, Unfasten the antenna bar: 23 단계, 이미지 2개 중 2개
    • Use a T5 Torx screwdriver to remove the six screws securing the antenna bar to the frame:
    • Two 7.5 mm screws
    • Four 3.2 mm screws
    • Use a P2 Pentalobe driver to remove the nine 1.5 mm screws securing the antenna bar to the frame.
    • These screws strip very easily; use constant downward pressure and work slowly when you loosen these.
  24. MacBook Pro 14" Early 2023 Screen Replacement, Remove the antenna bar: 24 단계, 이미지 2개 중 1개 MacBook Pro 14" Early 2023 Screen Replacement, Remove the antenna bar: 24 단계, 이미지 2개 중 2개
    • Insert the tip of a spudger between the antenna bar and the frame.
    • Pry up with the spudger to separate the antenna bar from the frame.
  25. MacBook Pro 14" Early 2023 Screen Replacement: 25 단계, 이미지 2개 중 1개 MacBook Pro 14" Early 2023 Screen Replacement: 25 단계, 이미지 2개 중 2개
    • Pull the antenna bar straight up and out of the frame to remove it.
  26. MacBook Pro 14" Early 2023 Screen Replacement, Unfasten the screen cable covers: 26 단계, 이미지 2개 중 1개 MacBook Pro 14" Early 2023 Screen Replacement, Unfasten the screen cable covers: 26 단계, 이미지 2개 중 2개
    • Use a 3IP Torx Plus driver to remove the four 2.1 mm screws securing the screen cable covers.
  27. MacBook Pro 14" Early 2023 Screen Replacement, Remove the screen cable covers: 27 단계, 이미지 2개 중 1개 MacBook Pro 14" Early 2023 Screen Replacement, Remove the screen cable covers: 27 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Use tweezers, or your fingers, to remove the two screen cable covers from the logic board.
  28. MacBook Pro 14" Early 2023 Screen Replacement, Disconnect the screen cables: 28 단계, 이미지 3개 중 1개 MacBook Pro 14" Early 2023 Screen Replacement, Disconnect the screen cables: 28 단계, 이미지 3개 중 2개 MacBook Pro 14" Early 2023 Screen Replacement, Disconnect the screen cables: 28 단계, 이미지 3개 중 3개
    • Use the flat end of a spudger to pry up and disconnect the two right-most screen cable press connectors secured to the logic board.
  29. MacBook Pro 14" Early 2023 Screen Replacement: 29 단계, 이미지 2개 중 1개 MacBook Pro 14" Early 2023 Screen Replacement: 29 단계, 이미지 2개 중 2개
    • Repeat the previous step for the left-most press connector.
  30. MacBook Pro 14" Early 2023 Screen Replacement, Remove the screen cable brackets: 30 단계, 이미지 3개 중 1개 MacBook Pro 14" Early 2023 Screen Replacement, Remove the screen cable brackets: 30 단계, 이미지 3개 중 2개 MacBook Pro 14" Early 2023 Screen Replacement, Remove the screen cable brackets: 30 단계, 이미지 3개 중 3개
    • Pull up on the back of the screen cable bracket to release the clips securing it to the frame.
    • Remove the screen cable bracket.
    • Repeat for the other screen cable bracket.
  31. MacBook Pro 14" Early 2023 Screen Replacement: 31 단계, 이미지 2개 중 1개 MacBook Pro 14" Early 2023 Screen Replacement: 31 단계, 이미지 2개 중 2개
    • If the two screen cable bracket buffers are removed alongside the brackets, then skip this step.
    • Pull the two screen cable bracket buffers straight up and out of the frame to remove them.
  32. MacBook Pro 14" Early 2023 Screen Replacement, Unfasten the lid angle sensor cover: 32 단계, 이미지 2개 중 1개 MacBook Pro 14" Early 2023 Screen Replacement, Unfasten the lid angle sensor cover: 32 단계, 이미지 2개 중 2개
    • Use a 3IP Torx Plus driver to remove the two 2.1 mm screws securing the lid angle sensor cover near the right hinge.
  33. MacBook Pro 14" Early 2023 Screen Replacement, Remove the lid angle sensor cover: 33 단계, 이미지 1개 중 1개
    • Use tweezers, or your fingers, to remove the lid angle sensor cover.
  34. MacBook Pro 14" Early 2023 Screen Replacement, Disconnect the lid angle sensor cable: 34 단계, 이미지 2개 중 1개 MacBook Pro 14" Early 2023 Screen Replacement, Disconnect the lid angle sensor cable: 34 단계, 이미지 2개 중 2개
    • Use the flat of a spudger to pry up and disconnect the lid angle sensor's press connector.
  35. MacBook Pro 14" Early 2023 Screen Replacement, Unfasten the hinge covers: 35 단계, 이미지 2개 중 1개 MacBook Pro 14" Early 2023 Screen Replacement, Unfasten the hinge covers: 35 단계, 이미지 2개 중 2개
    • Use your T5 Torx driver to remove the two 2.5 mm‑long screws securing each hinge cover (four screws in total).
  36. MacBook Pro 14" Early 2023 Screen Replacement, Remove the hinge covers: 36 단계, 이미지 3개 중 1개 MacBook Pro 14" Early 2023 Screen Replacement, Remove the hinge covers: 36 단계, 이미지 3개 중 2개 MacBook Pro 14" Early 2023 Screen Replacement, Remove the hinge covers: 36 단계, 이미지 3개 중 3개
    • Use tweezers to pull the hinge covers horizontally away from the hinge to separate it from the frame.
    • Remove the hinge covers.
  37. MacBook Pro 14" Early 2023 Screen Replacement, Remove some of the hinge screws: 37 단계, 이미지 2개 중 1개 MacBook Pro 14" Early 2023 Screen Replacement, Remove some of the hinge screws: 37 단계, 이미지 2개 중 2개
    • Use an 8IP Torx Plus driver to remove two 5.2 mm screws from each hinge (four screws total).
    • Each hinge has a third screw, which you should leave in place for now.
  38. MacBook Pro 14" Early 2023 Screen Replacement, Protect the MacBook: 38 단계, 이미지 2개 중 1개 MacBook Pro 14" Early 2023 Screen Replacement, Protect the MacBook: 38 단계, 이미지 2개 중 2개
    • If you plan to re-use your screen, open it and apply a piece of tape to the glass directly above each hinge. This helps protect the glass from getting scratched in the following three steps.
    • Fully open the screen and stand your MacBook Pro up on one side.
  39. MacBook Pro 14" Early 2023 Screen Replacement, Remove the remaining screws: 39 단계, 이미지 3개 중 1개 MacBook Pro 14" Early 2023 Screen Replacement, Remove the remaining screws: 39 단계, 이미지 3개 중 2개 MacBook Pro 14" Early 2023 Screen Replacement, Remove the remaining screws: 39 단계, 이미지 3개 중 3개
    • Use an 8IP Torx Plus driver to remove the two remaining 5.2 mm screws (one from each hinge).
    • Remove the topmost screw last, using one hand to steady both halves of the MacBook Pro to make sure they don't separate and fall over unexpectedly.
  40. MacBook Pro 14" Early 2023 Screen Replacement, Remove the screen: 40 단계, 이미지 3개 중 1개 MacBook Pro 14" Early 2023 Screen Replacement, Remove the screen: 40 단계, 이미지 3개 중 2개 MacBook Pro 14" Early 2023 Screen Replacement, Remove the screen: 40 단계, 이미지 3개 중 3개
    • Keep a firm grip on both the screen and main body of the MacBook Pro. Either half can fall unexpectedly during this step.
    • Push both halves of the MacBook Pro together so that the hinges can be lifted clear of their recesses in the chassis.
    • Push the main body of the MacBook Pro away from you while pulling the screen toward you to separate it.
  41. MacBook Pro 14" Early 2023 Screen Replacement: 41 단계, 이미지 1개 중 1개
    • Remove the screen.
  42. MacBook Pro 14" Early 2023 Screen Replacement: 42 단계, 이미지 2개 중 1개 MacBook Pro 14" Early 2023 Screen Replacement: 42 단계, 이미지 2개 중 2개
    • During reassembly, follow these instructions to align your screen hinges:
    • If you have blue threadlocker, apply a drop to each screw's threads to prevent them from loosening over time.
    • Install the hinge screws without fully tightening them. Center the hinges and check for gaps or rubbing on either side.
    • Fully tighten the hinge screws.
    • If your screen clicks or snaps when it's opened or closed, loosen the screws and realign the screen.
결론
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our MacBook Pro 14" 2023 Answers community for help.
다른 4명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Chayton Ritter
회원 가입일: 08/21/20
24,820 평판
안내서 105개를 작성함
Guide Team Guide Team 회원
Staff
10 회원들
안내서 15,763개를 작성함
2가이드 댓글
hello everyone, I also suffered from the artifact problem for a long time following a screen change.....but!!
after updating to version 15.2 beta the problem disappeared! (true tone didn't come back though)
EREIVIRED - 답글
Hello, planning to do the replacement as I crack my screen. Do you find it is easy to do? And hows the screen quality if I order from ifixit as well. Thanks!
Nguyen Minh -
댓글 쓰기
조회 통계:
지난 24시간: 8
지난 7일: 110
지난 30일: 424
전체 시간: 12,462
