소개
Install an Airport Extreme 802.11g card internally.
필요한 것
Use your fingers to push both battery release tabs away from the battery, and lift the battery out of the computer.
Remove the two 2.8 mm Phillips screws in the battery compartment near the latch.
Disconnect the three antenna cables attached to the Airport Extreme card.
거의 끝나갑니다!
결론
다른 12명이 해당 안내서를 완성하였습니다.
