이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
Change out the entire display assembly, including the inverter, Airport antennas, hinges and casing.
필요한 것
Use your fingers to push both battery release tabs away from the battery, and lift the battery out of the computer.
Remove the two 2.8 mm Phillips screws in the battery compartment near the latch.
Disconnect the three antenna cables attached to the Airport Extreme card.
다른 25명이 해당 안내서를 완성하였습니다.
