소개
The time and date, as well as other settings, are kept by the PRAM battery when your machine is off.
Use your fingers to push both battery release tabs away from the battery, and lift the battery out of the computer.
Disconnect the orange SuperDrive ribbon cable from the logic board, removing tape as necessary.
Disconnect the PRAM battery cable from the bottom right corner of the logic board.
다른 8명이 해당 안내서를 완성하였습니다.
댓글 한 개
Great Guide! Thanks! Got the weakened BIOS/PRAM changed, without having to touch the m/b at all, very fine!
