소개
This detects the internal temperature of your machine for heat management.
필요한 것
Use your fingers to push both battery release tabs away from the battery, and lift the battery out of the computer.
Disconnect the right fan cable from the logic board by placing a spudger beneath the cable and lifting up.
Disconnect the right thermal sensor cable from the logic board by placing a spudger beneath the cable and lifting up.
다른 한 분이 해당 안내서를 완성하였습니다.
