소개
Change out the entire display assembly, including the inverter, Airport antennas, hinges and casing.
Use your fingers to push both battery release tabs away from the battery, and lift the battery out of the computer.
Remove the three identical 2mm Phillips screws from the memory door.
Lift the memory door up enough to grip it and slide it toward you, pulling it away from the casing.
Lift up at the rear of the case and work your fingers along the sides, freeing the case as you go. Once you have freed the sides, you may need to rock the case up and down to free the front of the upper case.
There are four plastic clips above the DVD slot, and another above and to the left of the IR sensor. These clips can be very difficult to disengage without prying. They can also be difficult to re-engage during reassembly.
Disconnect the two or three antenna cables attached to the Airport Extreme card. Depending on your model, one of the three cables may be unused and capped with a black shrink tube.
Support the display with one hand while removing the following screws:
One 9.5 mm silver T6 Torx screw with threads on only 3 mm of the shaft on the inside of the display hinges.
One 9.5 mm silver T6 Torx screw with threads on the entire shaft on the outside of the left hinge.
One 9.2 mm full thread T6 Torx screw securing the iSight cable ground loop to the fan.
다른 109명이 해당 안내서를 완성하였습니다.
댓글 2개
Excellent job here and iFixit of course gets a nod with the author Walter Galan. It was reassuring to take apart. Having been inside the ole 2008 Penryn beast no biggie. But following the steps here for removing the screen was a treat. Better yet, having the photos to make sure the cables laid down properly when being reattached was reassuring. Thank you Walter!
Completed this in just over 30 minutes and not rushing.
waltdetmer - 답글
