주요 콘텐츠로 건너뛰기
이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
MacBook Pro 15" Core 2 Duo Models A1226 and A1260 ExpressCard Cage Replacement
필요한 것
  1. MacBook Pro 15" Core 2 Duo Models A1226 and A1260 ExpressCard Cage Replacement, Battery: 1 단계, 이미지 1/3 MacBook Pro 15" Core 2 Duo Models A1226 and A1260 ExpressCard Cage Replacement, Battery: 1 단계, 이미지 2/3 MacBook Pro 15" Core 2 Duo Models A1226 and A1260 ExpressCard Cage Replacement, Battery: 1 단계, 이미지 3/3
    • Use your fingers to push both battery release tabs away from the battery, and lift the battery out of the computer.
  2. MacBook Pro 15" Core 2 Duo Models A1226 and A1260 ExpressCard Cage Replacement, RAM Shield: 2 단계, 이미지 1/2 MacBook Pro 15" Core 2 Duo Models A1226 and A1260 ExpressCard Cage Replacement, RAM Shield: 2 단계, 이미지 2/2
    • Remove the three identical 2mm Phillips screws from the memory door.
    • Lift the memory door up enough to grip it and slide it toward you, pulling it away from the casing.
  3. MacBook Pro 15" Core 2 Duo Models A1226 and A1260 ExpressCard Cage Replacement, Upper Case: 3 단계, 이미지 1/1
    • Remove the two 2.8 mm Phillips screws in the battery compartment near the latch.
  4. MacBook Pro 15" Core 2 Duo Models A1226 and A1260 ExpressCard Cage Replacement: 4 단계, 이미지 1/1
    • Remove the following 6 screws:
    • Two 10 mm T6 Torx screws on either side of the RAM slot.
    • Four 14.5 mm Phillips screws along the hinge.
  5. MacBook Pro 15" Core 2 Duo Models A1226 and A1260 ExpressCard Cage Replacement: 5 단계, 이미지 1/1
    • Remove the four 3.2 mm PH00 Phillips screws on the port side of the computer.
  6. MacBook Pro 15" Core 2 Duo Models A1226 and A1260 ExpressCard Cage Replacement: 6 단계, 이미지 1/1
    • Rotate the computer 90 degrees and remove the two 3.2 mm Phillips screws from the rear of the computer.
  7. MacBook Pro 15" Core 2 Duo Models A1226 and A1260 ExpressCard Cage Replacement: 7 단계, 이미지 1/1
    • Rotate the computer 90 degrees again and remove the four 3.2 mm Phillips screws from the side of the computer.
  8. MacBook Pro 15" Core 2 Duo Models A1226 and A1260 ExpressCard Cage Replacement: 8 단계, 이미지 1/3 MacBook Pro 15" Core 2 Duo Models A1226 and A1260 ExpressCard Cage Replacement: 8 단계, 이미지 2/3 MacBook Pro 15" Core 2 Duo Models A1226 and A1260 ExpressCard Cage Replacement: 8 단계, 이미지 3/3
    • Do not yank the upper case off quickly. The case is attached to the logic board via a ribbon cable.
    • Lift up at the rear of the case and work your fingers along the sides, freeing the case as you go. Once you have freed the sides, you may need to rock the case up and down to free the front of the upper case.
    • There are four plastic clips above the DVD slot, and another above and to the left of the IR sensor. These clips can be very difficult to disengage without prying. They can also be difficult to re-engage during reassembly.
    • Reassembly Tip: Press down firmly on the tip of the top case above the location of each clip until you hear a snap to reseat them in their slots.
    • Reassembly Tip: The two center DVD clips will rarely snap back into place properly without help, and downward pressure will instead simply deform the frame around the DVD slot. Support the frame by inserting a plastic spudger into the DVD slot directly under the clip location until it is snug, then press down until you hear the snap.
  9. MacBook Pro 15" Core 2 Duo Models A1226 and A1260 ExpressCard Cage Replacement: 9 단계, 이미지 1/2 MacBook Pro 15" Core 2 Duo Models A1226 and A1260 ExpressCard Cage Replacement: 9 단계, 이미지 2/2
    • Disconnect the trackpad and keyboard ribbon cable from the logic board, removing tape as necessary.
    • Note: It is possible to replace the hard drive without disconnecting the keyboard from the chassis, but it will need to be held upright to keep it out of the way, while still allowing you both hands to work on the drive removal.
    • Be careful when removing the keyboard-trackpad ribbon cable to ensure that the rear of the upper case is disengaged from the area near the hinge. It is easy to accidentally bend the screw receivers on either side of the keyboard.
    • Remove the upper case.
  10. MacBook Pro 15" Core 2 Duo Models A1226 and A1260 ExpressCard Cage Replacement, Left Fan: 10 단계, 이미지 1/1
    • Use a spudger to disconnect the iSight cable from the logic board by sliding the cable to the left and out of its connector.
  11. MacBook Pro 15" Core 2 Duo Models A1226 and A1260 ExpressCard Cage Replacement: 11 단계, 이미지 1/2 MacBook Pro 15" Core 2 Duo Models A1226 and A1260 ExpressCard Cage Replacement: 11 단계, 이미지 2/2
    • Disconnect the left fan and left ambient light sensor cables by placing a spudger beneath each cable and lifting up.
    • Pry up from beneath the wires.
    • Peel up the left ambient light sensor cable from above the left fan, removing tape as necessary.
  12. MacBook Pro 15" Core 2 Duo Models A1226 and A1260 ExpressCard Cage Replacement: 12 단계, 이미지 1/2 MacBook Pro 15" Core 2 Duo Models A1226 and A1260 ExpressCard Cage Replacement: 12 단계, 이미지 2/2
    • Remove the following 3 screws:
    • One 6.2 mm black T6 Torx screw from the right side of the fan.
    • Two 9.4 mm silver T6 Torx screws from the left side of the fan.
    • Lift the fan up; carefully peel up the tape that secures the fan to the heat sink as you go.
  13. MacBook Pro 15" Core 2 Duo Models A1226 and A1260 ExpressCard Cage Replacement, ExpressCard Cage: 13 단계, 이미지 1/1
    • Disconnect the hard drive and ExpressCard connectors from the left side of the logic board.
  14. MacBook Pro 15" Core 2 Duo Models A1226 and A1260 ExpressCard Cage Replacement: 14 단계, 이미지 1/1
    • Disconnect the two antenna cables attached to the Airport Extreme card.
    • Apple was kind enough to include a label showing where each color antenna cable plugs in - just make sure to look at this when reconnecting the antenna cables.
  15. MacBook Pro 15" Core 2 Duo Models A1226 and A1260 ExpressCard Cage Replacement: 15 단계, 이미지 1/2 MacBook Pro 15" Core 2 Duo Models A1226 and A1260 ExpressCard Cage Replacement: 15 단계, 이미지 2/2
    • Remove the single black 4mm T6 Torx screw located just above the Airport Extreme card.
    • Remove the metal bracket that was securing the Airport Extreme card.
  16. MacBook Pro 15" Core 2 Duo Models A1226 and A1260 ExpressCard Cage Replacement: 16 단계, 이미지 1/3 MacBook Pro 15" Core 2 Duo Models A1226 and A1260 ExpressCard Cage Replacement: 16 단계, 이미지 2/3 MacBook Pro 15" Core 2 Duo Models A1226 and A1260 ExpressCard Cage Replacement: 16 단계, 이미지 3/3
    • Lift the Airport Extreme card up and slide it out of its connector.
    • Deroute the Airport antenna cables from their channel in the left speaker.
    • Peel up the orange hard drive cable from above the ExpressCard cage.
  17. MacBook Pro 15" Core 2 Duo Models A1226 and A1260 ExpressCard Cage Replacement: 17 단계, 이미지 1/2 MacBook Pro 15" Core 2 Duo Models A1226 and A1260 ExpressCard Cage Replacement: 17 단계, 이미지 2/2
    • Use a spudger to disconnect the speaker cable from the corner of the left I/O board.
    • Lift the left speaker assembly out of its housing and place it in the area previously occupied by the left fan.
  18. MacBook Pro 15" Core 2 Duo Models A1226 and A1260 ExpressCard Cage Replacement: 18 단계, 이미지 1/1
    • Disconnect the large gray and black power cable from the left I/O board.
  19. MacBook Pro 15" Core 2 Duo Models A1226 and A1260 ExpressCard Cage Replacement: 19 단계, 이미지 1/1
    • Use a spudger to disconnect the inverter cable from the corner of the left I/O board.
  20. MacBook Pro 15" Core 2 Duo Models A1226 and A1260 ExpressCard Cage Replacement: 20 단계, 이미지 1/2 MacBook Pro 15" Core 2 Duo Models A1226 and A1260 ExpressCard Cage Replacement: 20 단계, 이미지 2/2
    • Remove the following 5 screws/standoffs:
    • Four black 4 mm T6 Torx screws securing the left I/O board to the lower case.
    • One 4 mm standoff located between the audio jacks.
    • Lift up the right side of the left I/O board and slide it out of the computer.
  21. MacBook Pro 15" Core 2 Duo Models A1226 and A1260 ExpressCard Cage Replacement: 21 단계, 이미지 1/2 MacBook Pro 15" Core 2 Duo Models A1226 and A1260 ExpressCard Cage Replacement: 21 단계, 이미지 2/2
    • Remove the following four screws:
    • One 3.1 mm at upper right.
    • One 4.9 mm at upper left.
    • Two 2.2 mm along the bottom.
    • Lift the left I/O board off the ExpressCard cage.
결론
다른 5명이 해당 안내서를 완성하였습니다.
Walter Galan
694,495 평판
안내서 1,203개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 10
전체 시간: 15,183
