이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Use your fingers to push both battery release tabs away from the battery, and lift the battery out of the computer.
Remove the three identical 2mm Phillips screws from the memory door.
Lift the memory door up enough to grip it and slide it toward you, pulling it away from the casing.
Remove the two 2.8 mm Phillips screws in the battery compartment near the latch.
Remove the following 6 screws:
Two 10 mm T6 Torx screws on either side of the RAM slot.
Four 14.5 mm Phillips screws along the hinge.
Remove the four 3.2 mm PH00 Phillips screws on the port side of the computer.
Rotate the computer 90 degrees and remove the two 3.2 mm Phillips screws from the rear of the computer.
Rotate the computer 90 degrees again and remove the four 3.2 mm Phillips screws from the side of the computer.
Lift up at the rear of the case and work your fingers along the sides, freeing the case as you go. Once you have freed the sides, you may need to rock the case up and down to free the front of the upper case.
There are four plastic clips above the DVD slot, and another above and to the left of the IR sensor. These clips can be very difficult to disengage without prying. They can also be difficult to re-engage during reassembly.
Disconnect the trackpad and keyboard ribbon cable from the logic board, removing tape as necessary.
Remove the upper case.
Disconnect the two or three antenna cables attached to the Airport Extreme card. Depending on your model, one of the three cables may be unused and capped with a black shrink tube.
Deroute the Airport antenna cables from their channel in the left speaker.
Disconnect the iSight cable from the logic board by sliding the cable to the left and out of its connector.
Support the display with one hand while removing the following screws:
One 9.5 mm silver T6 Torx screw with threads on only 3 mm of the shaft on the inside of the display hinges.
One 9.5 mm silver T6 Torx screw with threads on the entire shaft on the outside of the left hinge.
One 9.2 mm full thread T6 Torx screw securing the iSight cable ground loop to the fan.
Disconnect the inverter cable from the left I/O board by placing a spudger beneath the cable and lifting up.
Disconnect the display data cable from the logic board.
Remove the foam bumper from the top of the right hinge of the display.
Remove the silver 9.2 mm T6 Torx securing the ground loop in the display data cable to the casing.
Support the display with one hand while removing the following screw:
Grasp the display assembly on both sides and lift it up and out of the computer.
Remove the 4.5 mm Phillips screws from the lower left and right corners of the display (two screws total). These screws have a .8 mm thick head.
Insert the flat end of a spudger perpendicular to the face of the display between the plastic strip attached to the rear bezel and the front bezel.
With the spudger still inserted, rotate it away from the display to separate the front and rear bezels.
Work along the right edge of the display until the rear bezel is evenly separated from the front bezel.
Insert your spudger between the front and rear display bezels at the lower right corner of the display.
Pry the rear bezel away from the front bezel to slightly separate the bottom edge of the rear display bezel.
Insert the flat end of a spudger into the gap between the rear display bezel and the clutch cover.
Twist the spudger to separate the lower edge of the rear display bezel from the clutch cover.
Work along the lower edge of the rear bezel until it is evenly separated from the clutch cover.
Now that the right and bottom edges of the rear bezel are slightly separated from the front bezel, use a spudger to pop the rear bezel off the tabs near the lower right corner of the display.
Insert the flat end of a spudger between the front bezel and the plastic strip attached to the rear bezel near the screw holes at the bottom corners of the display.
Rotate your spudger toward the rear bezel to separate it from the front bezel.
Slightly lift the lower edge of the display and pull it away from the rear display bezel.
Go here for the guide to continue replacing the screen: MacBook Pro 15" Core 2 Duo Models A1226 and A1260 LCD Panel Replacement
Use the tip of a spudger to lift the LED driver board out of the clutch cover.
Disconnect the backlight cable by pulling its connector away from the socket on the LED driver board.
Disconnect the LED driver cable by pulling its connector away from the socket on the inverter board.
Remove the LED driver board and set it aside.
Remove the two pieces of kapton tape covering the display data cable.
Remove the strip of tape securing the iSight cable to the LCD.
Peel the three antenna straps off the lower edge of the LCD.
Disconnect the display data cable by pulling its connector toward the bottom edge of the display, away from the socket on the LCD.
Remove the two Phillips screws securing the ground straps for the display data cable and LED driver board cable to the clutch cover.
Remove the three Phillips screws behind antenna straps along the bottom edge of the display.
To remove the clutch assembly, first insert the flat end of a spudger into the gap between the clutch hinge and the clutch cover where the cables exit.
While prying the clutch assembly away from the clutch hinge with your spudger, use a plastic opening tool to increase the gap between the clutch cover and the front display bezel.
Work your way along the length of the clutch cover to fully separate the adhesive.
Push the clutch assembly off each of the clutch hinges and remove it from the display.
Use the edge of a plastic opening tool to flip up the ZIF cable lock.
Slide the iSight cable out of its socket.
Remove the four T6 Torx screws securing the left clutch hinge to the front display bezel.
De-route the display data cable from the right clutch hinge and set it aside.
Remove the four T6 Torx screws securing the right clutch hinge to the front display bezel.
Remove the right clutch hinge and set it aside.
Remove the four Phillips screws from each side of the display (eight screws total).
Peel the large piece of tape near the display latch off the top edge of the LCD.
Remove the pieces of tape securing the camera ribbon cable to the display.
Use the flat end of a spudger to gently lift one of the top corners of the LCD out of the front bezel.
Work your way along the top edge of the LCD, slowly prying the attached steel strip away from the front bezel.
Continue prying the LCD off the front bezel along the left side of the display.
Now that the top edge is free, slightly lift the LCD out of the front bezel for enough room to pry the steel strip along the lower edge of the LCD away from the front bezel.
Pry along the lower edge of the LCD until it is freed from the adhesive on the front bezel.
Lift the LCD out of the front bezel, minding any cables that may get caught.
Front bezel remains.
다른 31명이 해당 안내서를 완성하였습니다.
댓글 한 개
Some advice on re-threading some of the wires would be helpful when putting things back together. Or when you are taking the display off, pay attention to how the cables are threaded through the hinges.
