이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Use your fingers to push both battery release tabs away from the battery, and lift the battery out of the computer.
Remove the three identical 2mm Phillips screws from the memory door.
Lift the memory door up enough to grip it and slide it toward you, pulling it away from the casing.
Release the tabs on each side of the RAM chip at the same time. These tabs lock the chip in place and releasing them will cause the chip to "pop" up.
Pull the chip directly out from its connector.
다른 222명이 해당 안내서를 완성하였습니다.
댓글 한 개
Really easy to install RAM on Macbook Pro 15'' Model A1226!!
I had 2GB of RAM (1GB and 1GB), so when I read this tutorial I decided to buy one ram of 2GB 667Mhz and It is working great (now I've got a total of 3 GB). I'm willing to install up to 6 GB with this same tutorial. Recommended!
