소개
This in an internal private guide that serves as a prereq.
필요한 것
Remove the pieces of yellow kapton tape from the bottom left corner of the display.
Peel the three green antenna ground straps off the copper tape along the bottom edge of the LCD.
Remove the piece of tape securing the camera cable to the LCD.
If you have a Core Duo machine, refer to picture 1 and remove three Phillips screws connecting the clutch assembly to the lower edge of the front display bezel near the display data cable.
If you have a Core 2 Duo Model A1211 machine, refer to picture 2 and remove two Phillips screws connecting the clutch assembly to the lower edge of the front display bezel near the display data cable.
The replacement antenna I just bought has all the adhesive cleaned off of the green ground straps. What do I use to glue them back on?
Aaron - 답글
That's a great question Aaron, I am also curious if you can just use contact adhesive, although mine has a copper strip adhered to the back of the LCD, which I am sure is used to increase the gain of the antenna, if so regular contact adhesive may act as a insulator and not be the best solution.
Jose Francisco Medeiros - 답글
