주요 콘텐츠로 건너뛰기
MacBook Pro 15" Core Duo Model A1150 Speakers Replacement
필요한 것
  1. MacBook Pro 15" Core Duo Model A1150 Speakers Replacement, Battery: 1 단계, 이미지 1/1
    • Use your fingers to push both battery release tabs away from the battery, and lift the battery out of the computer.
  2. MacBook Pro 15" Core Duo Model A1150 Speakers Replacement, Memory Door: 2 단계, 이미지 1/1
    • Remove the three identical Phillips screws from the memory door.
    • Make sure to record which sets of screws came from where. This will help when re-assembling.
  3. MacBook Pro 15" Core Duo Model A1150 Speakers Replacement: 3 단계, 이미지 1/1
    • Lift the memory door up enough to get a grip on it, and slide it toward you, pulling it away from the casing.
  4. MacBook Pro 15" Core Duo Model A1150 Speakers Replacement, Upper Case: 4 단계, 이미지 1/1
    • Remove the two Phillips screws in the battery compartment near the latch.
  5. MacBook Pro 15" Core Duo Model A1150 Speakers Replacement: 5 단계, 이미지 1/1
    • Remove the following 6 screws:
    • Two 10 mm T6 Torx screws on either side of the RAM slot.
    • Four 14.5 mm Phillips screws along the hinge.
  6. MacBook Pro 15" Core Duo Model A1150 Speakers Replacement: 6 단계, 이미지 1/1
    • Remove the four Phillips screws on the port side of the computer.
  7. MacBook Pro 15" Core Duo Model A1150 Speakers Replacement: 7 단계, 이미지 1/1
    • Rotate the computer 90 degrees and remove the two Phillips screws from the rear of the computer.
  8. MacBook Pro 15" Core Duo Model A1150 Speakers Replacement: 8 단계, 이미지 1/1
    • Rotate the computer 90 degrees again and remove the four Phillips screws from the side of the computer.
  9. MacBook Pro 15" Core Duo Model A1150 Speakers Replacement: 9 단계, 이미지 1/1
    • Do not yank the upper case off quickly. The case is attached to the logic board via a ribbon cable.
    • Lift up at the rear of the case and work your fingers along the sides, freeing the case as you go. Once you have freed the sides, you may need to rock the case up and down to free the front of the upper case. This stage can be quite tricky. Over the DVD reader are 4 tabs set back which pull out vertically.
    • Note that the two small tongues on the left hand front of the upper case may bend while you remove the upper case. When re-installing, you may need to bend them back to fit in the grooves in the lower case.
  10. MacBook Pro 15" Core Duo Model A1150 Speakers Replacement: 10 단계, 이미지 1/1
    • Disconnect the trackpad and keyboard ribbon cable from the logic board, removing tape as necessary.
    • Remove the upper case.
  11. MacBook Pro 15" Core Duo Model A1150 Speakers Replacement, Speakers: 11 단계, 이미지 1/1
    • Disconnect the display data cable from the logic board.
  12. MacBook Pro 15" Core Duo Model A1150 Speakers Replacement: 12 단계, 이미지 1/1
    • Peel up and remove the orange foil shield near the right speaker.
  13. MacBook Pro 15" Core Duo Model A1150 Speakers Replacement: 13 단계, 이미지 1/1
    • Remove the silver T6 Torx securing the ground loop in the display data cable to the casing.
  14. MacBook Pro 15" Core Duo Model A1150 Speakers Replacement: 14 단계, 이미지 1/1
    • Rotate the speaker clockwise approximately 30 degrees until it comes free from the logic board.
  15. MacBook Pro 15" Core Duo Model A1150 Speakers Replacement: 15 단계, 이미지 1/1
    • Peel up the gray and black speaker wires from the top of the logic board, removing tape as necessary.
  16. MacBook Pro 15" Core Duo Model A1150 Speakers Replacement: 16 단계, 이미지 1/1
    • Use a spudger to flip up the brown plastic flap securing the left ambient light sensor cable to the logic board.
    • Slide the left ambient light sensor cable to the left and out of its connector.
  17. MacBook Pro 15" Core Duo Model A1150 Speakers Replacement: 17 단계, 이미지 1/1
    • Peel up the left ambient light sensor cable from above the left fan.
  18. MacBook Pro 15" Core Duo Model A1150 Speakers Replacement: 18 단계, 이미지 1/1
    • Disconnect the two antenna cables attached to the Airport Extreme card.
    • The white antenna cable connects to the left side of the Airport Extreme card.
  19. MacBook Pro 15" Core Duo Model A1150 Speakers Replacement: 19 단계, 이미지 1/1
    • Remove the single silver Phillips screw located just above the Airport Extreme card.
    • Lift the small silver metal retaining bracket up and out of the computer.
  20. MacBook Pro 15" Core Duo Model A1150 Speakers Replacement: 20 단계, 이미지 1/1
    • Peel back the orange tape on the right side of the Airport Extreme card.
    • Lift the Airport Extreme card up and slide it out of its connector.
  21. MacBook Pro 15" Core Duo Model A1150 Speakers Replacement: 21 단계, 이미지 1/1
    • Disconnect the orange hard drive ribbon cable from the logic board.
  22. MacBook Pro 15" Core Duo Model A1150 Speakers Replacement: 22 단계, 이미지 1/1
    • Peel up the orange hard drive ribbon from above the ExpressCard cage.
  23. MacBook Pro 15" Core Duo Model A1150 Speakers Replacement: 23 단계, 이미지 1/1
    • Disconnect the speaker cable from the front right corner of the left I/O board.
  24. MacBook Pro 15" Core Duo Model A1150 Speakers Replacement: 24 단계, 이미지 1/1
    • Remove the following 2 screws:
    • One 4.3 mm black T6 Torx screw on the left side of the speaker.
    • One 9.4 mm silver T6 Torx screw on the right side of the speaker.
  25. MacBook Pro 15" Core Duo Model A1150 Speakers Replacement: 25 단계, 이미지 1/1
    • Lift the left and right speakers out of the computer.
  26. MacBook Pro 15" Core Duo Model A1150 Speakers Replacement: 26 단계, 이미지 1/1
    • Remove the single silver Phillips screw securing the left ambient light sensor cover to the speaker.
    • Remove the clear plastic ambient light sensor cover.
  27. MacBook Pro 15" Core Duo Model A1150 Speakers Replacement: 27 단계, 이미지 1/1
    • Use a spudger to pry the left ambient light sensor board out of its housing on the left speaker.
결론
다른 4명이 해당 안내서를 완성하였습니다.
iRobot
회원 가입일: 09/24/09
1 평판
안내서 636개 작성하였습니다
댓글 한 개
Step 14 was a bit tricky for me. Before you can rotate the speaker clockwise you need to lift up the transparent plastic cover so it's free from the speaker. Otherwise it was hard to turn it. If it has been there for a long time it can be jammed. Be careful.
Fredrik - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 22
전체 시간: 15,462
